Process Mining
Letzte Aktualisierung 25. Nov. 2025
Autopilot™ for Business logic editor (preview)
Autopilot for Business logic editor is a suite of AI-powered features that assists you in creating or modifying expressions using natural language. It reduces the need to manually construct complex syntax and helps you work faster and more intuitively.
When you enter a descriptive text prompt, Autopilot for Business logic editor interprets it and automatically generates or updates the corresponding expression.
Depending on the input, Autopilot can:
  • Generate a new expression from scratch, or
  • Modify an existing expression without requiring you to manually edit it.
To get started with Autopilot for Business logic editor, select the Autopilot icon from the header bar. This opens the Autopilot chat window, where you can choose from default prompts or enter a prompt yoursef to start an Autopilot chat.
Weitere Informationen finden Sie unter Über Autopilot Chat im Autopilot-Benutzerhandbuch.
Beispiele
You can enter natural language prompts to create or modify expressions. For example:
  • The prompt Can you create an expression for average costs? generates a new expression to calculate the average costs.
  • The prompt sum of event cost per case creates an expression similar to SUM([Event cost]) GROUPED by[Case ID] in the logic configuration.
  • The prompt Change to use throughput time instead of event cost updates the current expression, replacing the Event cost field with Throughput time.
  • Beispiele
Hilfe erhalten
UiPath Community-Forum
Vertrauen und Sicherheit
© 2005–2025 UiPath. Alle Rechte vorbehalten
