- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Checksum offloading on a network card may cause issues in some setups, including on VMware instances and in Cilium. If you encounter such issues, take the following steps:
- Disable TX checksum offloading by running the
following commands:
For server machines:
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-server.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksumcat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-server.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum -
For agent machines:
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-agent.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksumcat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-agent.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum
- Restart the affected instance by taking the steps described in Starting and shutting down a node.
