- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
AWS Deployment Architecture
This page provides general guidance on deploying Automation Suite to Azure.
Architecture Diagram
Components
- A highly available architecture that spans two or more Availability Zones.
- A virtual private cloud (VPC) configured with public and private subnets, according to AWS best practices, to provide you with your own virtual network on AWS.
- In the public subnets:
- A Linux bastion host to control inbound SSH (port 22) access to Amazon Elastic Compute Cloud (Amazon EC2) instances in the private subnets.
- Security groups for fine-grained inbound access to bastion host instance.
- In the private subnets:
- An Amazon EC2 Auto Scaling group with Kubernetes server nodes. Nodes are hosted on Amazon EC2 instances running RedHat 8.3.
- An Amazon EC2 Auto Scaling group with Kubernetes agent nodes. Nodes are hosted on Amazon EC2 instances running RedHat 8.3
- A database subnet group for Amazon Relational Database Service (Amazon RDS) DB instances running SQL Server.
- An Application Load Balancer or a Network Load Balancer to balance 443 inbound traffic between all kubernetes nodes.
- An internal Network Load Balancer to balance 6443 (the kube API) and 9345 (the RKE2 registration address) traffic between the kubernetes server nodes.
- Security groups for fine-grained access to the Kubernetes server nodes, as well as the agent nodes.
- AWS Certificate Manager for domain registration with a Secure Sockets Layer certificate.
- Amazon Route 53 as Domain Name System provider to route traffic to the Application Load Balancer.
- Multiple AWS Identity and Access Management (IAM) roles granting access to various operations required during deployment and installation.
