Performing Node Operations
DocumentationDescription
Adding a new node to the clusterHow to scale your deployment by adding additional nodes.
Removing a node from the clusterHow to safely remove a node from the cluster on a multi-node HA-ready production setup.
Repaving a cluster nodeHow to repave cluster nodes without any risks.
Shutting down a nodeHow to perform a graceful node shutdown.
Renaming a nodeBest practices for renaming nodes.
Performing node maintenanceWhat to do before and after a node maintenance operation, to ensure the cluster is healthy.
Connect
Stay updated
