- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to Disable TLS 1.0 and 1.1
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Redis Probe Failure
- RKE2 Server Fails to Start
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Enabling Redis High Availability Add-on for the Cluster
In a multi-node HA-ready production setup, High Availability (HA) is enabled by default. However, the Redis-based in-memory cache used by cluster services is running on a single node and represents a single point of failure. To mitigate the impact of a cache node failure or restart, you can purchase the High Availability Add-on (HAA), which enables redundant, multi-node HA-ready production deployment of the cache.
All installations include the HAA software with a single-node license. This license is free of cost, no purchase required.
If you wish to enable HAA across multiple nodes, then purchasing an HAA license is required. This will implement full high availability for the cluster in a multi-node HA-ready production setup.
HAA is based on Redis technology.
To do that, take the following steps:
- Purchase an HAA license. Contact UiPath for details.
Update the following fields in the
cluster_config.json
file:fabric.redis.license
- enter the HAA license converted to a single base64 string. In bash you can do that usingecho 'license_text_here' | base64 -w0
fabric.redis.ha
- usetrue
to enable HAA and make sure to also configure thefabric.redis.license
parameter. This enables HAA database replication and increases the number of HAA pods to 3. By default,fabric.redis.ha
is set tofalse
.Note: Ifredis.ha
is enabled,redis.license
needs to be set to a license that supports more than two shards."fabric": { "redis": { "ha": "true", "license": Base64String } }
- Rerun the fabric installer:
online installations:
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement
./install-uipath.sh -i cluster_config.json -f -o output.json --accept-license-agreement -
offline installations:
./install-uipath.sh -i cluster_config.json -f --install-type offline -o output.json --accept-license-agreement
