- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
dbo and read. Both tables store data from Orchestrator databases and pass data between each other. Over time, tables store a large amount
of data that can impact database performance. You can free up space by removing data that is not relevant or outdated.
The estimated threshold for storing historical data is set to
- 200 million RobotLogs
- 100 million QueueItemEvents
- 100 million JobEvents
- 20 million QueueItems
- 20 million Job
[dbo].Jobs, [dbo].JobEvents, [dbo].QueueItems, [dbo].QueueItemEvents, [dbo].RobotLogs tables, or just the [dbo].RobotLogs.
PROCEDURE
[read].[Delete_Insights_Data_Read] and PROCEDURE
[read].[Delete_Process_Logs_Read] scripts, the Insights module needs to be
disabled.
- Scripts with the
_DBOsuffix are used to delete data from DBO schema tables, - Scripts with the
_Readsuffix are used to delete data from Read schema tables. - Large-sized batches might impact the speed of execution. Consider using the default batch size, which is set to 100000.
PROCEDURE [read].[Delete_Insights_Data_Read] and
PROCEDURE [read].[Delete_Process_Logs_Read] scripts, the Insights module
needs to be disabled.
Jobs, JobEvents, QueueItems, QueueItemEvents, RobotLogs) for a cut-off timestamp.
| SQL Stored Procedures | Parameter | Description |
| Delete_Insights_Data_DBO |
| Delete data from [dbo].[Jobs],
[dbo].[JobEvents], [dbo].[QueueItems], [dbo].[QueueItemEvents], [dbo].[RobotLogs] tables based on a cut-off timestamp.
| Delete_Insights_Data_Read | N/A | Truncate [read].Jobs, [read].JobEvents,[read].QueueItems, [read].QueueItemEvents, [read].RobotLogs tables.
The Insights Dashboard widgets are available again after SQL Stored Procedure 1 has finished, and the data has been backfilled. Keep in mind that the backfill process may take hours to complete given that you have a large amount of data.
Delete_Insights_Data_DBO SQL Script, it creates a QueueItems.IX_CreationTime nonclustered index with the purpose of making future executions faster.
Generate and save this SQL Stored Procedure to delete RobotsLogs based on ProcessNames and Tenant ID.
| Delete_Process_Logs_DBO |
The Orchestrator process name.
Tenant ID is required as two tenants might run processes with identical names.
Delete data in batches of 100000. See Considerations. | Delete data from [dbo].[RobotLogs] table by ProcessName and Tenant ID.
| Delete_Process_Logs_Read |
| Truncate [read].RobotLogs table.
