- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Recommended: GCP Deployment Template
This page provides general guidance on deploying Automation Suite to GCP.
Important:
You can currently use the GCP deployment template only with Automation Suite 2024.10. We therefore recommend referring to the Automation Suite 2024.10 documentation.
| Step | Instructions |
| GCP deployment architecture | Architecture diagram Components Known limitations |
| Step 1: Preparing the GCP deployment | Prerequisites Quotas VM family region availability |
| Step 2: Deploying Automation Suite to GCP | Configuring the deployment Deployment parameters Completing the deployment |
| Step 3: Post-deployment steps | Updating certificates Accessing the deployment outputs Output definitions Accessing the services Accessing Automation Suite portal Accessing ArgoCD Accessing Rancher Accessing the cluster Editing the number of nodes |
