OUT OF SUPPORT
Last updated Feb 24, 2025
How to disable TLS 1.0 and 1.1
TLS 1.0 and 1.1 are deprecated, and enabling these versions in a clean installation can pose a security risk. You are strongly recommended to upgrade to TLS 1.2 or above instead of enabling lower versions on the server.
To enable TLS 1.2 in a clean installation, run the following command:
kubectl -n istio-system patch gateway main-gateway --type=json \
    -p='[{ "op": "replace", "path": "/spec/servers/0/tls/minProtocolVersion", "value": "TLSV1_2"}]'kubectl -n istio-system patch gateway main-gateway --type=json \
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
