OUT OF SUPPORT
Last updated Feb 24, 2025
Step 3: Configuring Azure SQL
Tip:
In this section, you will provision and configure an SQL Server.
Each service uses a DB with its own specifications.
  • In the installation process, the default option is to give the installer access to the SQL Server so it can create the required databases.
  • As an alternative option, you could also create the databases manually using the default DB names listed in Configuring Microsoft SQL Server (single-node evaluation or multi-node HA-ready production).
  1. Go to Azure SQL from the home page.
  2. Go to the Azure SQL, select Create, choose Database server as your SQL database deployment option, and then click Create.
  3. Fill in the required fields and click Next:
    Important: We do not support the following characters in the SQL username and password: ; # @ ?.
  4. Under the Networking tab, select yes for allow Azure Services and click Next:
  5. Click Next
  6. Fill in any tags required and click Next:
    (Optional step - only if you require tags on internal policies, otherwise ignore)
  7. Review the information and click Create:
  8. Wait until the deployment is complete:
The next step is Step 4: Configuring the DNS.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
