- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Maintenance and Backup
Upgrade Infrastructure on Servers
As part of this command, we take the backup of the Cluster state as well and pause all the further scheduled backups.
Note: This command also creates a backup of the cluster state and pauses all other scheduled backups.
Upgrade Infrastructure on Agents
Execute Rest of the Upgrade on the Primary Server
Preparation
Cluster Cleanup
- Copy and run the dedicated script to uninstall everything from that node. Do this for all the nodes. For details, see Troubleshooting.
- Restore all UiPath databases to the older backup that was created before the upgrade.
