- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
The Automation Suite cluster is exposing multiple URLs to access the cluster management tools and the suite core functionality, all based on a common FQDN.
You need to configure the DNS for the common FQDN and the subdomains specific to each tool as shown in the following table.
Application |
Domain |
Example URL |
Automation Suite |
Application Lifecycle Management (ALM) |
Monitoring / Observability |
Object Store |
Docker Registry |
Insights |
A Record in Advanced DNS or Management section of your domain as shown in the following table:
Type |
Host |
Value |
A Record (or CName)
automationsuite (or a subdomain to access Automation Suite)
A Record (or CName)
*.automationsuite (or a subdomain to access Automation Suite)
* wildcard is too generic, add a separate record or rule for the following subdomains: alm, monitoring, objectstore, registry, and insights.
As a workaround, you can use a private domain for testing purposes only.
For an example, see Sample Azure infrastructure setup.
