OUT OF SUPPORT
Last updated Feb 24, 2025
Node Draining Does Not Occur for Stopped Nodes
If a node is stopped in a cluster and, and its corresponding pods are not rescheduled to available nodes after 15 minutes, run the following script to manually drain the node.
#!/bin/sh
KUBECTL="/usr/local/bin/kubectl"
# Get only nodes which are not drained yet
NOT_READY_NODES=$($KUBECTL get nodes | grep -P 'NotReady(?!,SchedulingDisabled)' | awk '{print $1}' | xargs echo)
# Get only nodes which are still drained
READY_NODES=$($KUBECTL get nodes | grep '\sReady,SchedulingDisabled' | awk '{print $1}' | xargs echo)
echo "Unready nodes that are undrained: $NOT_READY_NODES"
echo "Ready nodes: $READY_NODES"
for node in $NOT_READY_NODES; do
  echo "Node $node not drained yet, draining..."
  $KUBECTL drain --ignore-daemonsets --force --delete-emptydir-data $node
  echo "Done"
done;
for node in $READY_NODES; do
  echo "Node $node still drained, uncordoning..."
  $KUBECTL uncordon $node
  echo "Done"
done;#!/bin/sh
  echo "Done"
done;
  echo "Done"
done;
  • Description
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
