OUT OF SUPPORT
Last updated Feb 24, 2025
GSSAPI Operation Failed With Error: An Invalid Status Code Was Supplied (Client's Credentials Have Been Revoked).
This log could be found when using Kerberos for SQL access, and SQL connection is failing inside services. Similarly, you may see kinit: Client's credentials have been revoked while getting initial credential in one of the following job names: services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
Solution
This could be caused by the AD user account used to generate the keytab being disabled. Re-enabling the AD user account should fix the issue.
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
