- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
MongoDB uses two types of certificates for a secure connection within the Automation Suite cluster:
- CA root certificate
- TLS certificate
The MongoDB CA certificate for Automation Suite versions prior to 2021.10.3 is only valid for 60 days. Since there is no auto-renewal process in place, a manual procedure is needed to update the certificate. Follow the steps from the Manual certificate update section to renew the certificates.
For Automation Suite versions 2021.10.4 and later, the expiry is updated to three years. For fresh installs of 2021.10.4 and later, the certificate renewal is automatic.
For environments upgraded from version 2021.10.3 and earlier, some manual steps are needed. Follow the steps from the Certificate rotation section to update the certificates.
Online Environment
This procedure is applicable for online environments.
Prerequisites
mongo-cert-rotation-script.sh containing the information below.
export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin
curl -sSL -o kubectl-cert-manager.tar.gz https://github.com/cert-manager/cert-manager/releases/download/v1.6.0/kubectl-cert_manager-linux-amd64.tar.gz
tar xzf kubectl-cert-manager.tar.gz
sudo mv kubectl-cert_manager /usr/local/bin
function update_additional_secrets() {
#extract updated pem file name
newPemFileName=$(kubectl -n mongodb get secret mongodb-replica-set-server-certificate-key -o json | jq -r '.data'| jq -r keys[0])
echo "New pem file name ${newPemFileName}"
#extract stale pem file name
oldPemFile=$(kubectl -n mongodb get secret mongodb-replica-set-config -o json | jq -r '.data."cluster-config.json"' | base64 -d | jq -r '.processes[0].args2_6.net.tls.certificateKeyFile')
oldPemFileName=$(basename "$oldPemFile")
echo "Stale pem file name ${oldPemFileName}"
if [[ "$oldPemFileName" != "$newPemFileName" ]]; then
echo "Pem file entries do not match. replacing"
#extract replica set secret cluser config json to file
kubectl -n mongodb get secret mongodb-replica-set-config -o json | jq -r '.data."cluster-config.json"' | base64 -d > /tmp/clusterConfig.json
#replace old pem file name with new in the json file
sed -i -e "s@$oldPemFileName@$newPemFileName@g" /tmp/clusterConfig.json
#encode the json
encodedUpdatedClusterConfig=$(jq -r '. | @base64 | "\)\)(.)"' /tmp/clusterConfig.json)
#patch replica set secret with updated cluster config
kubectl -n mongodb patch secret mongodb-replica-set-config --type='json' -p='[{"op" : "replace" ,"path" : "/data/cluster-config.json" ,"value" : "'"$encodedUpdatedClusterConfig"'"}]'
else
echo "Pem file entries match; not updating"
fi
function rotate_secrets(){
NAMESPACE="mongodb"
#shellcheck disable=SC2154
HOME_DIR=$(eval echo "~$whoami")
echo "extracting certs and secrets from relevant files"
#cleanup if the dir already exists
rm -rf "$HOME_DIR"/tmp/.certs || true
mkdir -p "$HOME_DIR"/tmp/.certs/
kubectl -n "$NAMESPACE" get secret/tls-ca-key-pair -o jsonpath='{.data.ca\)\).crt}' | base64 -d > "$HOME_DIR"/tmp/.certs/ca.crt
kubectl -n "$NAMESPACE" create configmap mongo-ca --from-file="$HOME_DIR/tmp/.certs/ca.crt" --dry-run=client -o yaml | kubectl apply -f -
kubectl -n mongodb label configmap mongo-ca config-discovery=yes 2>/dev/null || true
PREVIOUS_REVISION=$(kubectl -n mongodb get cert cert-manager-tls-certificate -o json | jq -r '.status.revision')
echo "Previous Version"
echo $PREVIOUS_REVISION
kubectl cert-manager renew --namespace=mongodb --all
sleep 60
CURRENT_REVISION=$(kubectl -n mongodb get cert cert-manager-tls-certificate -o json | jq -r '.status.revision')
echo "Current Version"
echo $CURRENT_REVISION
#Validate if Cert gets renewed
if [[ "${PREVIOUS_REVISION}" != "${CURRENT_REVISION}" ]]; then
echo "Cert Renewal Successful. Previous Revision: $PREVIOUS_REVISION Current Revision: $CURRENT_REVISION"
echo "Rotating secrets"
rotate_secrets
echo "Secrets rotated"
echo "Updating additional secrets"
echo "Additional secrets updated"
echo "Rolling restart mongodb replica set"
kubectl rollout restart sts mongodb-replica-set -n mongodb
echo "Mongodb replica successfully Restarted"
echo "Rolling restart apps server"
kubectl rollout restart -n uipath deployment apps-server
echo "Apps server successfully restarted"
echo "Rolling restart apps-wsserver"
kubectl rollout restart -n uipath deployment apps-wsserver
echo "Apps wsserver successfully restarted"
else
echo "Cert Renewal UnSuccessful. Previous Revision: $PREVIOUS_REVISION Current Revision: $CURRENT_REVISION"
fi
rm -rf /usr/local/bin/kubectl-cert_managerexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin
#encode the json
else
fi
NAMESPACE="mongodb"
sleep 60
rotate_secrets
else
fi
rm -rf /usr/local/bin/kubectl-cert_managerProcedure
Offline Environment
This procedure is applicable for offline (airpgapped) environments.
Prerequisites
mongo-airgap-cert-rotation-script.sh
#encode the json
else
fi
NAMESPACE="mongodb"
sleep 60
rotate_secrets
else
fi
#encode the json
else
fi
NAMESPACE="mongodb"
sleep 60
rotate_secrets
else
fi
Download the
kubectl-cert-manager.tarfile on your system by running the following command:curl -sSL -o kubectl-cert-manager.tar.gz https://github.com/cert-manager/cert-manager/releases/download/v1.6.0/kubectl-cert_manager-linux-amd64.tar.gzcurl -sSL -o kubectl-cert-manager.tar.gz https://github.com/cert-manager/cert-manager/releases/download/v1.6.0/kubectl-cert_manager-linux-amd64.tar.gz -
Copy the certificate manager binary to the VM node by running the following command:
scp <path-to-kubectl-cert-manager> <username>@<node-fqdn>:~scp <path-to-kubectl-cert-manager> <username>@<node-fqdn>:~ -
Copy the script from Prerequisites (
mongo-airgap-cert-rotation-script.sh) to the VM node by running the following commands:scp <path-to-mongo-airgap-cert-rotation> <username>@<node-fqdn>:~scp <path-to-mongo-airgap-cert-rotation> <username>@<node-fqdn>:~ -
Connect to the machine using SSH.
ssh <username>@<node-fqdn>ssh <username>@<node-fqdn> -
Copy the
kubectl-cert-manager.tarfile to the installer directory by running the following command:mv /home/<username>/kubectl-cert_manager.tar.gz <installer-dir>mv /home/<username>/kubectl-cert_manager.tar.gz <installer-dir> - Copy the
mongo-airgap-cert-rotation-script.shscript to the installer directory by running the following command:
mongo-airgap-cert-rotation-script.sh and kubectl-cert-manager.tar files are at the same path.
mv /home/<username>/mongo-airgap-cert-rotation-script.sh <installer-dir>
cd <installer-dir>mv /home/<username>/mongo-airgap-cert-rotation-script.sh <installer-dir>
cd <installer-dir>notBefore and notAfter fields.
kubectl -n mongodb describe certsexport KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin:/usr/local/bin
kubectl -n mongodb describe certs8. Run the script using the following commands:
chmod u+x mongo-airgap-cert-rotation-script.sh
./mongo-airgap-cert-rotation-script.shchmod u+x mongo-airgap-cert-rotation-script.sh
./mongo-airgap-cert-rotation-script.shnotBefore and notAfter fields.
kubectl -n mongodb describe certskubectl -n mongodb describe certsCertificate validity dates
When checking for certificate validity, the following dates are displayed:
Not After - this is the expiry date and time of your certificate validiy period.
Not Before - this is the starting date and time of your certificate validity period.
Renewal Time - this is the recommended date and time for manually renewing your certificate.
For example:
Certificate 1 in the file
Namespace: mongodb
Not After: 2023-03-08T23:19:49Z
Not Before: 2022-03-08T23:19:49Z
Renewal Time: 2023-02-06T23:19:49ZCertificate 1 in the file
Namespace: mongodb
Renewal Time: 2023-02-06T23:19:49Z-
SSH to the VM node.
Assume the super user role by running the command below.
sudo susudo su -
Go to the installation (for fresh installations) or upgrade (for upgraded environments) directory by running the command below.
cd <Installation/Upgrade Directory>cd <Installation/Upgrade Directory> -
Copy the
rotate-cert.shscript below to the installation directory../configureUiPathAS.sh mongodb rotate-certificate kubectl -n mongodb get secret/tls-ca-key-pair -o jsonpath='{.data.ca\)\).crt}' | base64 -d > /tmp/.certs/ca.crt kubectl -n mongodb create configmap mongo-ca --from-file="/tmp/.certs/ca.crt" --dry-run=client -o yaml | kubectl replace -f - kubectl rollout restart sts mongodb-replica-set -n mongodb./configureUiPathAS.sh mongodb rotate-certificate kubectl -n mongodb get secret/tls-ca-key-pair -o jsonpath='{.data.ca\)\).crt}' | base64 -d > /tmp/.certs/ca.crt kubectl -n mongodb create configmap mongo-ca --from-file="/tmp/.certs/ca.crt" --dry-run=client -o yaml | kubectl replace -f - kubectl rollout restart sts mongodb-replica-set -n mongodb -
Run the certificate rotation script by using the command below.
chmod u+x rotate-cert.sh ./rotate-cert.shchmod u+x rotate-cert.sh ./rotate-cert.sh
The certificate rotation script takes around 5-10 minutes to complete. The new certificates generated by the script are valid for three years from the time of creation and are automatically renewed as per the timeline mentioned above.
