Automation Suite
- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to Disable TLS 1.0 and 1.1
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Redis Probe Failure
- RKE2 Server Fails to Start
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite Installation Guide
Last updated Apr 19, 2024
Occasionally, after cluster restore/rollback to version 2022.4.x or 2021.10.x, an issue causes MongoDB or business applications (Apps) pods to get stuck in the initial state. This happens because the volume required for attaching the PVC to a pod is missing.
Verify if the problem is indeed related to MongoDB volume attachment issue:
# fetch all mongodb pods kubectl -n mongodb get pods #describe pods stuck in init state #kubectl -n mongodb describe pods mongodb-replica-set-<replica index number> kubectl -n mongodb describe pods mongodb-replica-set-0
# fetch all mongodb pods kubectl -n mongodb get pods #describe pods stuck in init state #kubectl -n mongodb describe pods mongodb-replica-set-<replica index number> kubectl -n mongodb describe pods mongodb-replica-set-0If the issue is related to the MongoDB volume attachment, the following events are displayed:
Events: Type Reason Age From Message ---- ---- ---- Warning FailedAttachVolume 3m9s (x65 over 133m) attachdetach-controller AttachVolume.Attach failed for volume "pvc-66897693-e52d-4b89-aac6-ca0cc5ae9e07" : rpc error: code = Aborted desc = volume pvc-66897693-e52d-4b89-aac6-ca0cc5ae9e07 is not ready for workloads Warning FailedMount 103s (x50 over 112m) kubelet (combined from similar events): Unable to attach or mount volumes: unmounted volumes=[logs-volume], unattached volumes=[hooks mongodb-replica-set-keyfile tls-secret data-volume healthstatus tls-ca kube-api-access-45qcl agent-scripts logs-volume automation-config]: timed out waiting for the condition
Events: Type Reason Age From Message ---- ---- ---- Warning FailedAttachVolume 3m9s (x65 over 133m) attachdetach-controller AttachVolume.Attach failed for volume "pvc-66897693-e52d-4b89-aac6-ca0cc5ae9e07" : rpc error: code = Aborted desc = volume pvc-66897693-e52d-4b89-aac6-ca0cc5ae9e07 is not ready for workloads Warning FailedMount 103s (x50 over 112m) kubelet (combined from similar events): Unable to attach or mount volumes: unmounted volumes=[logs-volume], unattached volumes=[hooks mongodb-replica-set-keyfile tls-secret data-volume healthstatus tls-ca kube-api-access-45qcl agent-scripts logs-volume automation-config]: timed out waiting for the condition -
Fix the problematic MongoDB pods by running the following script:
#!/bin/bash set -eu FAILED_PVC_LIST="" STORAGE_CLASS_SINGLE_REPLICA="longhorn-backup-single-replica" STORAGE_CLASS="longhorn-backup" LOCAL_RESTORE_PATH="restoredata" mkdir -p ${LOCAL_RESTORE_PATH} export LOCAL_RESTORE_PATH="${LOCAL_RESTORE_PATH}" function delete_pvc_resources(){ local pv_name=$1 local volumeattachment_name=$2 echo "deleting pv & volumes forcefully" delete_pv_forcefully "${pv_name}" sleep 2 delete_longhornvolume_forcefully "${pv_name}" sleep 2 if [ -n "${volumeattachment_name}" ]; then echo "deleting volumeattachments forcefully" delete_volumeattachment_forcefully "${volumeattachment_name}" sleep 5 fi } function delete_longhornvolume_forcefully() { local pv_name=$1 if ! kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" >/dev/null 2>&1 ; then echo "Volume ${pv_name} not found, skip deletion." return fi kubectl -n longhorn-system delete volumes.longhorn.io "${pv_name}" --grace-period=0 --force & local success=0 local try=0 local maxtry=10 while (( try < maxtry )); do local result="" # update finaluzer field to null result=$(kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" -o=json | jq '.metadata.finalizers = null' | kubectl apply -f -) || true echo "${result}" result=$(kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}")|| true echo "${result}" if [[ -z "${result}" ]]; then success=1 break; fi kubectl -n longhorn-system delete volumes.longhorn.io "${pv_name}" --grace-period=0 --force & echo "Waiting to delete volume ${pv_name} ${try}/${maxtry}..."; sleep 10 try=$(( try + 1 )) done if [ "${success}" -eq 0 ]; then echo "Failed to delete volume ${pv_name}." fi } function delete_pv_forcefully() { local pv_name=$1 kubectl delete pv "${pv_name}" --grace-period=0 --force & local success=0 local try=0 local maxtry=10 while (( try < maxtry )); do # update finaluzer field to null result=$(kubectl get pv "${pv_name}" -o=json | jq '.metadata.finalizers = null' | kubectl apply -f -) || true echo "${result}" result=$(kubectl get pv "${pv_name}")|| true echo "${result}" if [[ -z "${result}" ]]; then success=1 break; fi kubectl delete pv "${pv_name}" --grace-period=0 --force & echo "Waiting to delete pv ${pv_name} ${try}/${maxtry}..."; sleep 10 try=$(( try + 1 )) done if [ "${success}" -eq 0 ]; then echo "Failed to delete pv ${pv_name}." fi } function validate_pv_backup_available(){ local pv_name=$1 local validate_pv_backup_available_resp=0 local backup_resp="" local resp_status_code="" local resp_message="" local try=0 local maxtry=3 while (( try != maxtry )) ; do backup_resp=$(curl --noproxy "*" "${LONGHORN_URL}/v1/backupvolumes/${pv_name}?") || true echo "Backup Response: ${backup_resp}" if { [ -n "${backup_resp}" ] && [ "${backup_resp}" != " " ]; }; then resp_status_code=$(echo "${backup_resp}"| jq -c ".status") resp_message=$(echo "${backup_resp}"| jq -c ".message") if [[ -n "${resp_status_code}" && "${resp_status_code}" != " " && "${resp_status_code}" != "null" && (( resp_status_code -gt 200 )) ]] ; then validate_pv_backup_available_resp=0 else resp_message=$(echo "${backup_resp}"| jq -c ".messages.error") if { [ -z "${resp_message}" ] || [ "${resp_message}" = "null" ]; }; then echo "PVC Backup is available for ${pv_name}" # shellcheck disable=SC2034 validate_pv_backup_available_resp=1 break; fi fi fi try=$((try+1)) sleep 10 done export IS_BACKUP_AVAILABLE="${validate_pv_backup_available_resp}" } function store_pvc_resources(){ local pvc_name=$1 local namespace=$2 local pv_name=$3 local volumeattachment_name=$4 if [[ -n "${volumeattachment_name}" && "${volumeattachment_name}" != " " ]]; then result=$(kubectl get volumeattachments "${volumeattachment_name}" -o json > "${LOCAL_RESTORE_PATH}/${volumeattachment_name}".json) || true echo "${result}" fi kubectl get pv "${pv_name}" -o json > "${LOCAL_RESTORE_PATH}/${pv_name}"-pv.json kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" -o json > "${LOCAL_RESTORE_PATH}/${pv_name}"-volume.json kubectl get pvc "${pvc_name}" -n "${namespace}" -o json > "${LOCAL_RESTORE_PATH}/${pvc_name}"-pvc.json } function wait_pvc_bound() { local namespace=$1 local pvc_name=$2 try=0 maxtry=30 while (( try < maxtry )); do local status="" status=$(kubectl -n "${namespace}" get pvc "${pvc_name}" -o json| jq -r ".status | select( has(\"phase\")).phase") if [[ "${status}" == "Bound" ]]; then echo "PVC ${pvc_name} Bouned successfully." break; fi echo "waiting for PVC to bound...${try}/${maxtry}"; sleep 30 try=$((try+1)) done } function create_volume() { local pv_name=$1 local backup_path=$2 local response create_volume_status="succeed" echo "Creating Volume with PV: ${pv_name} and BackupPath: ${backup_path}" local accessmode local replicacount accessmode=$(< "${LOCAL_RESTORE_PATH}/${pv_name}-volume.json" jq -r ".spec.accessMode") replicacount=$(< "${LOCAL_RESTORE_PATH}/${pv_name}-volume.json" jq -r ".spec.numberOfReplicas") # create volume from backup pv response=$(curl --noproxy "*" "${LONGHORN_URL}/v1/volumes" -H 'Accept: application/json' -H 'Content-Type: application/json;charset=UTF-8' --data-raw "{\"name\":\"${pv_name}\", \"accessMode\":\"${accessmode}\", \"fromBackup\": \"${backup_path}\", \"numberOfReplicas\": ${replicacount}}") sleep 5 if [[ -n "${response}" && "${response}" != "null" && "${response}" != " " && -n $(echo "${response}"|jq -r ".id") ]]; then # wait for volume to be detached , max wait 4hr local try=0 local maxtry=480 local success=0 while (( try < maxtry ));do status=$(kubectl -n longhorn-system get volumes.longhorn.io "${pv_name}" -o json |jq -r ".status.state") || true echo "volume ${pv_name} status: ${status}" if [[ "${status}" == "detached" ]]; then # update label kubectl -n longhorn-system label volumes.longhorn.io/"${pv_name}" recurring-job-group.longhorn.io/uipath-backup=enabled success=1 echo "Volume ready to use" break fi echo "waiting for volume to be ready to use${try}/${maxtry}..."; sleep 30 restore_status_url="${LONGHORN_URL}/v1/volumes/${pv_name}?action=snapshotList" try=$(( try + 1 )) done if [ "${success}" -eq 0 ]; then create_volume_status="failed" echo "${pv_name} Volume is not ready to use with status ${status}" fi else create_volume_status="failed" kubectl create -f "${LOCAL_RESTORE_PATH}/${pv_name}"-volume.json || true echo "${pv_name} Volume creation failed ${response} " fi echo "${create_volume_status}" } function restore_with_backupvolume() { local pvc_name=$1 local namespace=$2 local pv_name=$3 local volumeattachment_name=$4 local backup_path=$5 create_volume_status="succeed" store_pvc_resources "${pvc_name}" "${namespace}" "${pv_name}" "${volumeattachment_name}" sleep 5 delete_pvc_resources "${pv_name}" "${volumeattachment_name}" sleep 5 create_volume "${pv_name}" "${backup_path}" sleep 10 kubectl create -f "${LOCAL_RESTORE_PATH}/${pv_name}"-pv.json if [[ -n "${create_volume_status}" && "${create_volume_status}" != "succeed" ]]; then echo "Backup volume restore failed for pvc ${pvc_name} in namespace ${namespace}" restore_pvc_status="failed" else local pvc_uid="" pvc_uid=$(kubectl -n "${namespace}" get pvc "${pvc_name}" -o json| jq -r ".metadata.uid") # update pv with pvc uid kubectl patch pv "${pv_name}" --type json -p "[{\"op\": \"add\", \"path\": \"/spec/claimRef/uid\", \"value\": \"${pvc_uid}\"}]" wait_pvc_bound "${namespace}" "${pvc_name}" echo "${result}" fi echo ${restore_pvc_status} } function restore_pvc(){ local pvc_name=$1 local namespace=$2 local pv_name=$3 local volumeattachment_name=$4 local backup_path=$5 restore_pvc_status="succeed" restore_with_backupvolume "${pvc_name}" "${namespace}" "${pv_name}" "${volumeattachment_name}" "${backup_path}" echo ${restore_pvc_status} # attach_volume "${pv_name}" } function get_backup_list_by_pvname(){ local pv_name=$1 local get_backup_list_by_pvname_resp="" local backup_list_response="" local try=0 local maxtry=3 while (( try != maxtry )) ; do backup_list_response=$(curl --noproxy "*" "${LONGHORN_URL}/v1/backupvolumes/${pv_name}?action=backupList" -X 'POST' -H 'Content-Length: 0' -H 'Accept: application/json') if [[ -n "${backup_list_response}" && "${backup_list_response}" != " " && -n $( echo "${backup_list_response}"|jq ".data" ) && -n $( echo "${backup_list_response}"|jq ".data[]" ) ]]; then echo "Backup List Response: ${backup_list_response}" # pick first backup data with url non empty # shellcheck disable=SC2034 get_backup_list_by_pvname_resp=$(echo "${backup_list_response}"|jq -c '[.data[]|select(.url | . != null and . != "")][0]') break; fi try=$((try+1)) sleep 10 done export PV_BACKUP_PATH="${get_backup_list_by_pvname_resp}" } function get_pvc_resources() { get_pvc_resources_resp="" local PVC_NAME=$1 local PVC_NAMESPACE=$2 # PV have one to one mapping with PVC PV_NAME=$(kubectl -n "${PVC_NAMESPACE}" get pvc "${PVC_NAME}" -o json|jq -r ".spec.volumeName") VOLUME_ATTACHMENT_LIST=$(kubectl get volumeattachments -n "${PVC_NAMESPACE}" -o=json|jq -c ".items[]|\ {name: .metadata.name, pvClaimName:.spec.source| select( has (\"persistentVolumeName\")).persistentVolumeName}") VOLUME_ATTACHMENT_NAME="" for VOLUME_ATTACHMENT in ${VOLUME_ATTACHMENT_LIST}; do PV_CLAIM_NAME=$(echo "${VOLUME_ATTACHMENT}"|jq -r ".pvClaimName") if [[ "${PV_NAME}" = "${PV_CLAIM_NAME}" ]]; then VOLUME_ATTACHMENT_NAME=$(echo "${VOLUME_ATTACHMENT}"|jq -r ".name") break; fi done BACKUP_PATH="" validate_pv_backup_available "${PV_NAME}" local is_backup_available=${IS_BACKUP_AVAILABLE:- 0} unset IS_BACKUP_AVAILABLE if [ "${is_backup_available}" -eq 1 ]; then echo "Backup is available for PVC ${PVC_NAME}" get_backup_list_by_pvname "${PV_NAME}" BACKUP_PATH=$(echo "${PV_BACKUP_PATH}"| jq -r ".url") unset PV_BACKUP_PATH fi get_pvc_resources_resp="{\"pvc_name\": \"${PVC_NAME}\", \"pv_name\": \"${PV_NAME}\", \"volumeattachment_name\": \"${VOLUME_ATTACHMENT_NAME}\", \"backup_path\": \"${BACKUP_PATH}\"}" echo "${get_pvc_resources_resp}" } function scale_ownerreferences() { local ownerReferences=$1 local namespace=$2 local replicas=$3 # no operation required if [[ -z "${ownerReferences}" || "${ownerReferences}" == "null" ]]; then return fi ownerReferences=$(echo "${ownerReferences}"| jq -c ".[]") for ownerReference in ${ownerReferences}; do echo "Owner: ${ownerReference}" local resourceKind local resourceName resourceKind=$(echo "${ownerReference}"| jq -r ".kind") resourceName=$(echo "${ownerReference}"| jq -r ".name") if kubectl -n "${namespace}" get "${resourceKind}" "${resourceName}" >/dev/null 2>&1; then # scale replicas kubectl -n "${namespace}" patch "${resourceKind}" "${resourceName}" --type json -p "[{\"op\": \"replace\", \"path\": \"/spec/members\", \"value\": ${replicas} }]" fi done } function scale_down_statefulset() { local statefulset_name=$1 local namespace=$2 local ownerReferences=$3 echo "Start Scale Down statefulset ${statefulset_name} under namespace ${namespace}..." # validate and scale down ownerreference scale_ownerreferences "${ownerReferences}" "${namespace}" 0 local try=0 local maxtry=30 success=0 while (( try != maxtry )) ; do result=$(kubectl scale statefulset "${statefulset_name}" --replicas=0 -n "${namespace}") || true echo "${result}" scaledown=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}"|grep 0/0) || true if { [ -n "${scaledown}" ] && [ "${scaledown}" != " " ]; }; then echo "Statefulset scaled down successfully." success=1 break else try=$((try+1)) echo "waiting for the statefulset ${statefulset_name} to scale down...${try}/${maxtry}";sleep 30 fi done if [ ${success} -eq 0 ]; then echo "Statefulset ${statefulset_name} scaled down failed" fi } function scale_up_statefulset() { local statefulset_name=$1 local namespace=$2 local replica=$3 local ownerReferences=$4 # Scale up statefulsets using PVCs echo "Start Scale Up statefulset ${statefulset_name}..." # validate and scale up ownerreference scale_ownerreferences "${ownerReferences}" "${namespace}" "${replica}" echo "Waiting to scale up statefulset..." local try=1 local maxtry=15 local success=0 while (( try != maxtry )) ; do kubectl scale statefulset "${statefulset_name}" --replicas="${replica}" -n "${namespace}" kubectl get statefulset "${statefulset_name}" -n "${namespace}" scaleup=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}"|grep "${replica}"/"${replica}") || true if ! { [ -n "${scaleup}" ] && [ "${scaleup}" != " " ]; }; then try=$((try+1)) echo "waiting for the statefulset ${statefulset_name} to scale up...${try}/${maxtry}"; sleep 30 else echo "Statefulset scaled up successfully." success=1 break fi done if [ ${success} -eq 0 ]; then echo "Statefulset scaled up failed ${statefulset_name}." fi } function restore_pvc_attached_to_statefulsets() { local namespace namespace="${1}" local statefulset_list # list of all statefulset using PVC statefulset_list=$(kubectl get statefulset -n "${namespace}" -o=json | jq -r ".items[] | select(.spec.volumeClaimTemplates).metadata.name") for statefulset_name in ${statefulset_list}; do local replica local ownerReferences local pvc_restore_failed local try=0 local maxtry=5 local status="notready" pvc_restore_failed="" restore_pvc_status="" # check if statefulset is reday while [[ "${status}" == "notready" ]] && (( try < maxtry )); do echo "fetch statefulset ${statefulset_name} metadata... ${try}/${maxtry}" try=$(( try + 1 )) replica=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}" -o=json | jq -c ".spec.replicas") if [[ "${replica}" != 0 ]]; then status="ready" else echo "statefulset ${statefulset_name} replica is not ready. Wait and retry"; sleep 30 fi done if [[ "${status}" != "ready" ]]; then echo "Failed to restore pvc for Statefulset ${statefulset_name} in namespace ${namespace}. Please retrigger volume restore step." fi # Fetch ownerReferences and claim name ownerReferences=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}" -o=json | jq -c ".metadata.ownerReferences") claimTemplatesName=$(kubectl get statefulset "${statefulset_name}" -n "${namespace}" -o=json | jq -c ".spec | select( has (\"volumeClaimTemplates\") ).volumeClaimTemplates[].metadata.name " | xargs) echo "Scaling down Statefulset ${statefulset_name} with ${replica} under namespace ${namespace}" scale_down_statefulset "${statefulset_name}" "${namespace}" "${ownerReferences}" for name in ${claimTemplatesName}; do local pvc_prefix pvc_prefix="${name}-${statefulset_name}" for((i=0;i<"${replica}";i++)); do local pvc_name pvc_name="${pvc_prefix}-${i}" pvc_exist=$(kubectl -n "${namespace}" get pvc "${pvc_name}") || true if [[ -z "${pvc_exist}" || "${pvc_exist}" == " " ]]; then echo "PVC not available for the statefulset ${statefulset_name}, skipping restore." continue; fi local pvc_storageclass pvc_storageclass=$(kubectl -n "${namespace}" get pvc "${pvc_name}" -o json| jq -r ".spec.storageClassName") if [[ ! ( "${pvc_storageclass}" == "${STORAGE_CLASS}" || "${pvc_storageclass}" == "${STORAGE_CLASS_SINGLE_REPLICA}" ) ]]; then echo "backup not available for pvc ${pvc_name}, storageclass: ${pvc_storageclass} " continue; fi # get pv, volumeattachments for pvc get_pvc_resources_resp="" get_pvc_resources "${pvc_name}" "${namespace}" local pv_name local volumeattachment_name local backup_path pv_name=$(echo "${get_pvc_resources_resp}"| jq -r ".pv_name") volumeattachment_name=$(echo "${get_pvc_resources_resp}"| jq -r ".volumeattachment_name") backup_path=$(echo "${get_pvc_resources_resp}"| jq -r ".backup_path") if [[ -z "${backup_path}" || "${backup_path}" == " " || "${backup_path}" == "null" ]]; then pvc_restore_failed="error" FAILED_PVC_LIST="${FAILED_PVC_LIST},${pv_name}" continue; fi restore_pvc_status="succeed" restore_pvc "${pvc_name}" "${namespace}" "${pv_name}" "${volumeattachment_name}" "${backup_path}" if [[ -n "${restore_pvc_status}" && "${restore_pvc_status}" != "succeed" ]]; then pvc_restore_failed="error" FAILED_PVC_LIST="${FAILED_PVC_LIST},${pv_name}" continue; fi done done sleep 10 scale_up_statefulset "${statefulset_name}" "${namespace}" "${replica}" "${ownerReferences}" sleep 5 if [[ -n "${pvc_restore_failed}" && "${pvc_restore_failed}" == "error" ]]; then echo "Failed to restore pvc for Statefulset ${statefulset_name} in namespace ${namespace}." fi done } LONGHORN_URL=$(kubectl -n longhorn-system get svc longhorn-backend -o jsonpath="{.spec.clusterIP}"):9500 restore_pvc_attached_to_statefulsets "mongodb"
