- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Longhorn is successfully installed, but fails to create persistent volumes.
Solution
Verify if the kernel modules are successfully loaded in the cluster by using the command lsmod | grep <module_name>.
Replace <module_name> with each of the following kernel modules:
libiscsi_tcplibiscsiiscsi_tcpscsi_transport_iscsi
Load any missing module.
