- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
The server fails to start. There are a few different reasons for RKE2 not starting properly, which are usually found in the logs.
Solution
Check the logs using the following commands:
journalctl -u rke2-server
Possible reasons (based on logs): too many learner members in cluster
Too many etcd servers are added to the cluster, and there are two learner nodes trying to be promoted. More information here: Runtime reconfiguration.
Perform the following:
- Under normal circumstances, the node should become a full member if enough time is allowed.
- An uninstall-reinstall cycle can be attempted.
Alternatively, this could be caused by a networking problem. Ensure you have configured the machine to enable the necessary ports.
