- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
You can rename nodes during the Automation Suite installation. Make sure to give each node a distinct, non-default name. Avoid
using common default names, such as
localhost.localdomain, as this may potentially cause network conflicts or confusion due to transient hostnames assigned by DHCP.
Important:
Renaming a node post-installation is not supported. Attempting this operation could lead to a cluster failure.
