Installation best practices
To avoid your SSH session getting interrupted, we recommend initiating a tmux session and then running the installation process in the context of that session. If run under the tmux session, the SSH session can be interrupted, and you can reconnect to the previous session from where the installer was initiated.
Take the following steps:
  1. SSH into the remote machine.
  2. Install tmux on the machine using the following command:
    sudo yum install tmux
  3. Create a tmux session by running the following command.
    tmux new -s uipath_install
  4. Once inside tmux, you can start the installation process.
    • Commands such as the one below run in the session.
      ./installUiPathAS.sh
      sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j server --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /var/tmp --install-offline-prereqs --accept-license-agreement
    • To list all sessions, run the following command:
      tmux ls
      tmux ls
    • To connect to most recent session, run the following command:
      tmux a
      tmux a
    • To connect to a session by name, run the following command:
      tmux attach -t uipath_install
  5. To leave or detach from the tmux session, press Ctrl+B and then press D.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
