- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Migration Job Fails in ArgoCD
Migration job fails for Document Understanding in ArgoCD.
Solution
Document Understanding requires the FullTextSearch feature to be enabled on the SQL server. Otherwise, the installation can fail without an explicit error message in this regard, as the migration job fails in ArgoCD.
