- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Using the Orchestrator Configurator Tool
The Orchestrator Configurator Tool is a bash script that allows you to place files and settings inside the Orchestrator deployment in Automation Suite. The tool helps you add storage files, credential store plugins, NLog extensions, new NLog configurations, and override appSettings.
The environment where you use the Orchestrator Configurator Tool must be able to run a bash script and have the following tools:
- kubectl configured with a connection to the cluster
- jq 1.6
- s3cmd
Do not download and use the ArgoCD CLI tool independently. To maintain compatibility and ensure smooth operation, we recommend using the ArgoCD we bundle within the Automation Suite artifacts. To do that, you must add ArgoCD to your path from the latest installer by running the following command:
export PATH="$PATH:/opt/UiPathAutomationSuite/<version>/installer/bin"
To be able to run Orchestrator Configurator Tool from any location, follow these steps:
Update the
PATHvariable so as to include<installer-dir>/bin. For example:export PATH="$PATH:/opt/UiPathAutomationSuite/online_installer_2021.10.4/bin" -
Make sure that the
jq --versionutility version is 1.6. If it's not, update it through one of these options:yum install -y epel-release yum install -y jqcurl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpm jq --versionyum install -y epel-release yum install -y jqcurl https://download-ib01.fedoraproject.org/pub/epel/7/x86_64/Packages/j/jq-1.6-2.el7.x86_64.rpm --output /tmp/jq-1.6-2.el7.x86_64.rpm yum localinstall /tmp/jq-1.6-2.el7.x86_64.rpm jq --version
Example
Usage: ./orchestrator_configurator.sh \)\)
-s blobstoragefolder -p pluginsfolder -n nlogextensionsfolder \)\)
-c appsettings.custom.config -l nlog.custom.config
-c|--app-settings
application configuration file containing json with key-value structure
-l|--nlog-config-file
nlog config file, json
-s|--storage-folder
location of the storage folder on the local disk
-n|--nlog-extensions-folder
location of the nlog extensions on the local disk
-p|--securestore-plugins-folder
location of the securestore plugins on the local disk
-d|--dry-run
do not update the orchestrator app with the new values
-y|--accept-all
do not prompt for confirmation of actions and overwriting of files with kubectl cp.
-c|--app-settings
-s|--storage-folder
-d|--dry-run
-y|--accept-all
To apply new application settings, run the following command:
./orchestrator_configurator.sh -c appsettings.custom.json
Example appsettings.custom.config
"ExampleSetting.Enabled": true,
"ExampleSetting.Type": "BasicExample",
"ExampleSetting.Count": 3
To change NLog configuration, run the following command:
./orchestrator_configurator.sh -l nlog.custom.json
Example nlog.custom.config
"Nlog": {
"targets": {
"robotElasticBuffer": {
"flushTimeout": 1000,
"bufferSize": 1000,
"slidingTimeout": false,
"target": {
"uri": "https://elastic.example.com:9200",
"requireAuth": true,
"username": "elastic-user",
"password": "elastic-password",
"index": "${event-properties:item=indexName}-${date:format=yyyy.MM}",
"documentType": "logEvent",
"includeAllProperties": true,
"layout": "${message}",
"excludedProperties": "agentSessionId,tenantId,indexName"
"Nlog": {
"targets": {
"bufferSize": 1000,
"target": {
