- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Navigating to Insights homepage generates a 404
- Exploring Logs
OUT OF SUPPORT
Last updated Feb 24, 2025
Rarely, a routing error can occur and result in a 404 on the Insights home page. You can resolve this by going to the Insights application in ArgoCD and deleting the virtual service insightsprovisioning-vs. Note that you may have to select clear filters to show X additional resources to see and delete this virtual service.
