- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring SQL databases
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Certificate configuration
- Database configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Redirecting traffic for the unsupported services to the primary cluster
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 8: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Using the Orchestrator Configurator Tool
- Orchestrator appSettings
- Configuring appSettings
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to upgrade from Automation Suite 2022.10.10 and 2022.4.11 to 2023.10.2
- How to forward application logs to Splunk
- How to clean up unused Docker images from registry pods
- Test Automation SQL connection string is ignored
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Longhorn REST API endpoint upgrade/reinstall error
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated May 5, 2025
Checksum offloading on a network card may cause issues in some setups, including on VMware instances and in Cilium. If you encounter such issues, take the following steps:
- Disable TX checksum offloading by running the
following commands:
For server machines:
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-server.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-server.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum -
For agent machines:
cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service [Unit] Description=Disable TX Checksum Offload Before=rke2-agent.service Wants=network-online.target After=network-online.target [Service] Type=oneshot ExecStart=/bin/bash -c "INTERFACE=$(awk '$2 == 00000000 { print $1; exit }' /proc/net/route); ethtool -K \$INTERFACE tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true" RemainAfterExit=true [Install] WantedBy=multi-user.target EOF sudo systemctl enable disable-checksum
- Restart the affected instance by taking the steps described in Starting and shutting down a node.
