Downloading Installation Packages
Package
Purpose
installUiPathAS.sh
  • Installation
sf-installer.zip
  • Installation
  • Upgrade
  • Restore
  • New Node
sf.tar.gz
  • Installation
  • Upgrade
sf-infra.tar.gz
  • Installation
  • Upgrade
  • Restore
  • New Node
du-ondemand.tar.gz
  • Document Understanding installation
du2110-ondemand.tar.gz
cv-ondemand.tar.gz
  • Computer Vision installation
configureUiPathDisks.sh
  • Pre-installation for disk configuration
supportability-tools
  • Post-installation
Tip: This page provides instructions on downloading the files to the home directory of the current user. If you want to change the directory, make sure to provide the path to download using the -O parameter.
  • Overview
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
