Automation Suite
- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to Disable TLS 1.0 and 1.1
- How to enable Istio logging
- How to clean up old logs stored in the sf-logs bundle
- How to disable NIC checksum offloading
- Redis Probe Failure
- RKE2 Server Fails to Start
- Using the Automation Suite Support Bundle Tool
- Exploring Logs
Automation Suite Installation Guide
Last updated Apr 19, 2024
To debug Istio, you need to enable logging. To do that, perform the following steps:
Find the
istio-ingressgateway
pod by running the following command. Copy the gateway pod name. It should be something likeistio-ingressgateway-r4mbx
.kubectl -n istio-system get pods
kubectl -n istio-system get pods -
Open the gateway Pod shell by running the following command.
kubectl exec -it -n istio-system istio-ingressgateway-r4mbx bash
kubectl exec -it -n istio-system istio-ingressgateway-r4mbx bash -
Enable debug level logging by running the following command.
curl -X POST http://localhost:15000/logging?level=debug
curl -X POST http://localhost:15000/logging?level=debug -
Run the following command from a server node.
istioctl_bin=$(find /var/lib/rancher/rke2/ -name "istioctl" -type f -perm -u+x -print -quit) if [[ -n ${istioctl_bin} ]] then echo "istioctl bin found" kubectl -n istio-system get cm istio-installer-base -o go-template='{{ index .data "istio-base.yaml" }}' > istio-base.yaml kubectl -n istio-system get cm istio-installer-overlay -o go-template='{{ index .data "overlay-config.yaml" }}' > overlay-config.yaml ${istioctl_bin} -i istio-system install -y -f istio-base.yaml -f overlay-config.yaml --set meshConfig.accessLogFile=/dev/stdout --set meshConfig.accessLogEncoding=JSON else echo "istioctl bin not found" fi
