- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
During offline installation, at the fabric stage, the execution fails with the following error message:
Error: overlay: can't stat program "/usr/bin/fuse-overlayfs": stat /usr/bin/fuse-overlayfs: no such file or directory
Solution
You need to remove the line containing the mount_program key from the podman configuration /etc/containers/storage.conf.
Ensure you remove the line rather than comment it out.
