OUT OF SUPPORT
Last updated Feb 24, 2025
Orchestrator Pod in CrashLoopBackOff or 1/2 Running With Multiple Restarts
If the Orchestrator pod in CrashLoopBackOff or 1/2 is running with multiple restarts, the failure could be related to the authentication keys for the object storage provider, Ceph.
To check if the failure is related to Ceph, run the following commands:
kubectl -n uipath get pod -l app.kubernetes.io/component=orchestratorkubectl -n uipath get pod -l app.kubernetes.io/component=orchestrator
If the output of this command is similar to one of the following options, you need to run an additional command.
Option 1:
NAME                            READY   STATUS    RESTARTS   AGE
orchestrator-6dc848b7d5-q5c2q   1/2     Running   2          6m1s
OR
Option 2
orchestrator-6dc848b7d5-q5c2q   1/2     CrashLoopBackOff   6          16mOption 1:
OR
Option 2
Verify if the failure is related to Ceph authentication keys by running the following command:
kubectl -n uipath logs -l app.kubernetes.io/component=orchestrator | grep 'Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden' -okubectl -n uipath logs -l app.kubernetes.io/component=orchestrator | grep 'Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden' -o
If the output of the above command contains the string Error making request with Error Code InvalidAccessKeyId and Http Status Code Forbidden, the failure is due to the Ceph authentication keys.
Solution
Rerun the rook-ceph-configure-script-job and credential-manager jobs using the following commands:
kubectl -n uipath-infra get job "rook-ceph-configure-script-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
kubectl -n uipath-infra get job "credential-manager-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
kubectl -n uipath delete pod -l app.kubernetes.io/component=orchestratorkubectl -n uipath-infra get job "rook-ceph-configure-script-job" -o json | jq 'del(. | .spec.selector, .spec.template.metadata.labels)' | kubectl replace --force -f -
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
