- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Failure to Resize Objectstore PVC
- Storage reclamation patch
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Pods in RabbitMQ or cattle-monitoring-system or other StatefulSet pods are stuck in the init state.
Occasionally, upon node power failure or during upgrade, an issue causes the pods in RabbitMQ or cattle-monitoring-system to get stuck in init state as the volume required for attaching the PVC to a pod is missing.
Verify if the problem is indeed related to the StatefulSet volume attachment by running the following command:
kubectl -n <namespace> describe pod <pod-name> | grep "cannot get resource \"volumeattachments\" in API group \" storage.k8s.io\""
If it is related to the StatefulSet volume attachment, it will show an error message.
Solution
To fix this issue, reboot the node.
