How to disable TX checksum offloading
Checksum offloading on a network card may cause issues in some setups, including on VMware instances and in Cilium.
If you encounter such issues, you must disable the TX checksum offloading by running the following commands:
  • For server machines:
    cat <<EOF | sudo tee /etc/systemd/system/disable-checksum.service
    [Unit]
    Description=Disable TX Checksum Offload
    Before=rke2-server.service
    Wants=network-online.target
    After=network-online.target
    [Service]
    Type=oneshot
    ExecStart=/bin/bash -c "ethtool -K $(awk '$2 == 00000000 { print $1; exit }' /proc/net/route) tx-checksum-ip-generic off || ethtool -K cilium_host tx-checksum-ip-generic off || true"
    RemainAfterExit=true
    [Install]
    WantedBy=multi-user.target
    EOF
    sudo systemctl enable disable-checksum
    [Unit]
    [Service]
    Type=oneshot
    [Install]
    EOF
    [Unit]
    [Service]
    Type=oneshot
    [Install]
    EOF
    [Unit]
    [Service]
    Type=oneshot
    [Install]
    EOF
Connect
Stay updated
