- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
OUT OF SUPPORT
This error could be found in the log of a failed job, with one of the following job names:
services-preinstall-validations-job, kerberos-jobs-trigger, kerberos-tgt-update.
Make sure the AD user still exists, is active, and their password was not changed and did not expire. Reset the user's password and regenerate the keytab if needed.
Also make sure to provide the default Kerberos AD user parameter
<KERB_DEFAULT_USERNAME> in the following format: HTTP/<Service Fabric FQDN>.
