OUT OF SUPPORT
Last updated Feb 24, 2025
Step 1: Preparing the AWS deployment
This page lists the steps you need to take before deploying Automation Suite to AWS.
Important: To prevent data loss, ensure the infrastructure you use does not automatically delete cluster disks on cluster reboot or shutdown. If this capability is enabled, make sure to disable it.
Getting started on AWS
The AWS deployment requires a moderate level of familiarity with AWS services.
If you are new to AWS, you can start by reading the following introductory materials to get familiar. They provide basic materials for how to design, deploy, and operate infrastructure and applications on the AWS Cloud.
This Quick Start also assumes familiarity with AWS Services listed in the Request resources quotas section of this guide. For a detailed diagram and description of the architecture, see:
Creating an AWS account
If you don’t already have an AWS account, create one by following the step-by-step instructions. Your AWS account is automatically signed up for all AWS services. You are charged only for the services you use.
Configuring your AWS account
The following sections walk you through the steps you need to take to configure your AWS Account specific to the Automation Suite deployment requirements.
Amazon EC2 key pairs
You need at least one EC2 key pair in the AWS account in the Region where you will deploy the Quick Start.
To create a key pair, see Amazon EC2 key pairs and Linux instances.
Take note of the key-pair name as it is needed during the deployment.
Note: For testing or evaluation purposes, we recommend creating a new key pair instead of using an existing one.
Valid Domain Name
This Quick Start requires you to have established ownership of the parent domain under which the web application will be served. If you want to register a domain, see Registering a public domain.
If you have registered the domain using AWS Route 53, then the hosted zone is preconfigured, and no additional configuration is necessary.
Otherwise, you should set up a hosted zone in your AWS account, with the required name server, start of authority, CNAME, and text records. For further details on how to create a public hosted zone, see Working with public hosted zones.
Request Resource Quotas
If necessary, request service quota increases for the following resources. You might need to request increases if your existing deployment currently uses these resources and if this Quick Start deployment could result in exceeding the default quotas. The Service Quotas console displays your usage and quotas for some aspects of some services.
For more information, see What is Service Quotas? and AWS service quotas.
Resource
Requirement
VPCs
1
Subnets
Up to 6
NAT gateways
2
VPC endpoints
1
Internet gateways
1
Elastic IP addresses
Up to 6
AWS Identity and Access Management (IAM) security groups
1
IAM roles
Up to 7
Auto Scaling groups
Up to 2
Application Load Balancers
Either 0 or 1
Network Load Balancers
Either 1 or 2
Public certificate authorities (CA)
1
Hosted zone
1
RDS instances
1
Bastion hosts
1
Secrets
4
Lambda Functions
3
Instance Profiles
2
Security Groups
3
Supported AWS Regions
In order for the Quick Start to work in a Region other than its default Region, all the services that are part of the deployment must also be supported in that Region.
For an up-to-date list of AWS Regions and the AWS services they support, see AWS Regional Services.
Note: Certain Regions are available on an opt-in basis. For more information, see Managing AWS Regions.
To test whether a specific Region is supported, you can launch Quick Start for that Region and, if you get an error Unrecognized resource type, then Quick Start is not supported in that Region.
IAM permissions
Before launching the Quick Start, you must sign in to the AWS Management Console with IAM permissions for the resources that the templates deploy. The AdministratorAccess managed policy within IAM provides sufficient permissions, although your organization may choose to use a custom policy with more restrictions.
For more information, see AWS managed policies for job functions.
For a complete list of roles and policies that the CloudFormation template creates, see Roles and policies.
Connections to external endpoints
The following table describes all the external endpoints that the service interacts with:
Requirements
Details
AWS metadata service
Provides details about your Amazon EC2 instance
AWS management APIs
Used via AWS CLI or lambda functions
AWS bootstrap archive
Used for services to provision and manage resources. Retrieved from the following URL: https://s3.amazonaws.com/cloudformation-examples/aws-cfn-bootstrap-py3-latest.tar.gz
AWS CLI package
Used for the command line interface to interact with AWS services from a machine. You can access the package from the following URL: https://awscli.amazonaws.com/awscli-exe-linux-x86_64.zip
AWS SSM Agent
Used for managing instances via remote commands at scale. You can download the agent from the following URL: https://s3.${AWS::Region}.amazonaws.com/amazon-ssm-${AWS::Region}/latest/linux_amd64/amazon-ssm-agent.rpm
AWS Cloudwatch Agent
Used for collecting system and application logs for monitoring. You can download the agent from the following URL: https://s3.amazonaws.com/amazoncloudwatch-agent/redhat/amd64/latest/amazon-cloudwatch-agent.rpm
Nvidia drivers
Required for GPU-enabled VMs. You can get the drivers from the Nvidia repository.
External repository if used
N/A
UiPath S3 buckets for templates / lambda functions usage / bash scripts for installation.
N/A
For more details, see Network requirements.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
