- Overview
- Requirements
- Q&A: Deployment Templates
- Configuring the Machines
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Online multi-node HA-ready production installation
- Offline Multi-node HA-ready Production Installation
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
This page explains how you can perform an online Automation Suite installation with a multi-node HA-ready production setup.
Hardware and software prerequisites must be completed before proceeding with the installation. See Hardware and software requirements.
For a smooth installation experience, make sure to follow our best practices. See .
These steps will enable you to install the Automation Suite across multiple machines. Internet access is required for this mode of installation.
The installation process has the following general steps:
| Step | Description |
| Step 1: Download the Installation Packages | This step needs to be performed from a machine with access to internet where Automation Suite will be deployed. While these are finishing downloading you can continue onto some of the next steps. Step 1: Download the Install script and run interactive wizard |
| Step 2: Configure the Installation | Step 2.1: Run the interactive install wizard to configure the installation options The tool will gather inputs for most common install options and generate a configuration file that will be used during the installation. Step 2.1: Basic configuration Step 2.2: (Optional) Configure advanced installation options The default install configuration includes the products used in core automation and a shared SQL server to be used by all products. To customize the products installed or have separate SQL servers used for specific products you can do so by editing the configuration file. Step 2.2: (Optional) Advanced configuration |
| Step 3: Complete the installation | Step 3: You have completed the installation successfully and can move to post-installation steps. You can now access the newly created cluster and suite, update certificates, resize the PVC, and more. Step 3: Completing the installation |
Step 1: Downloading the installation script and running the interactive installer
You must perform this step from a machine with internet access where Automation Suite will be deployed. While these are finishing downloading, you can continue with the next steps.
The Automation Suite installer is a wrapper of multiple packages that also installs some dependencies using Red Hat Package Manager (RPM). It provides an interactive experience that helps you configure external resources such as SQL and other installation options.
To copy the interactive installer to the target machine, take the following steps:
Connect to the first machine using SSH.
If you set a password, the command is as follows:
ssh <user>@<dns_of_vm>ssh <user>@<dns_of_vm> -
If you used an SSH key, the command is as follows:
ssh -i <path/to/Key.pem> <user>@<dns_of_vm>ssh -i <path/to/Key.pem> <user>@<dns_of_vm>
Become root.
sudo su -sudo su - -
Move to home directory:
cd ~cd ~ -
Download the
installUiPathAS.shinstaller. For instructions, see installUiPathAS.sh. Make sure to download the package suitable for your Automation Suite version. -
Install
unzipandjq.yum install unzip jq -yyum install unzip jq -y
Step 2: Configuring the installation
Run the installer on the first server only.
chmod +x ~/installUiPathAS.sh
./installUiPathAS.sh
Run the interactive installer to configure the installation options. The tool gathers inputs for the most common installation options and generates a configuration file that you can use during the installation.
If you run the installation using the default configuration, you opt for the default experience. You will install our core platform, Orchestrator, Insights, Action Center, Test Manager, Automation Ops, and Automation Hub.
High Availability is enabled by default, but you can disable it using the advanced configuration.
To install Automation Suite using the interactive installer, take the following steps:
Select Install the UiPath Automation Suite.
Select the deployment mode: select multi-node.
Select continue.
Select online installation.
Enter the DNS hostname / load balancer URL.
Specify whether you want to use Kerberos Auth for SQL connections.
Enter the SQL Server URL. Follow the prompt to enter the connection port, username, and password.
Enter whether you want the installer to auto-create the necessary DBs (Select Yes unless you have existing Automation Suite Databases).
Once the configuration parameters are defined, the installer will autogenerate the configuration. You can edit the configuration parameters directly in the terminal.
You can also see guidance and more details for certificates at Configuring the certificates. Note that certificates are autogenerated, and we recommend rotating them after installation is complete.
Note:At this point, you can directly edit the
cluster_config.jsonfile for advanced configuration settings in theUiPathAutomationSuitefolder. After you edit the configuration file, you can re-run the wizard to complete the installation or complete manually. You can go to the following section here: Advanced configuration step for more details. -
At this point, you can proceed with the installation.
The process will complete and you will have the first node set up:
To continue with the multi-node HA-ready production installation, run the command provided by the wizard on all the nodes in the terminal in sequence, specifying the agent or server for each node being joined.
Note:You can also add additional nodes post-installation. For details, see Adding a new node to the cluster.
Once all the machines are joined, run the next command on the first server to complete installation of services:
By running the installation using the default configuration, you are opting to run our basic product selection. You will install our core platform, Orchestrator, Insights, Action Center, Test Manager, Automation Ops, and Automation Hub.
You can configure the file for more advanced configurations. You can enable additional products, disable any of the default products, configure your SQL DBs and their respective connection strings, and certificates. For multi-node HA-ready production mode, we enable High Availability by default, but you can disable it if needed.
For advanced configuration, you can follow the following instructions: Advanced installation experience.
Step 3: Completing the Installation
You have completed the installation successfully, and you can now move to post-installation steps.
Updating Certificates
The installation process generates self-signed certificates on your behalf. However, the Azure deployment template also gives you the option to provide a CA-issued server certificate at installation time instead of using an auto-generated self-signed certificate.
Self-signed certificates will expire in 90 days, and you must replace them with certificates signed by a trusted CA as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
Accessing Automation Suite
To access the newly created cluster and suite, see Accessing Automation Suite.
Resizing PVC
To resize the PVC, see Resizing PVC.
If you installed AI Center, we recommend resizing the PVC to 200 immediately after the installation to avoid downtimes. For more information on this, check Resizing PVC for AI Center.
- Overview
- Step 1: Downloading the installation script and running the interactive installer
- Step 2: Configuring the installation
- Step 2.1: Basic configuration
- Step 2.2: (Optional) Advanced configuration
- Step 3: Completing the Installation
- Updating Certificates
- Accessing Automation Suite
- Resizing PVC
