- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
On top of the core service requirements that are part of full platform requirements, AI Center requires additional resources, depending on the models that you want to run or train. For more details about the required GPU hardware generations and compatible NVIDIA drivers, refer to Compatibility Matrix.
The following table describes the additional resources AI Center needs. In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
Use |
CPU |
RAM (GiB) |
GPU |
Disk (GiB) |
Minimum for serving (ML Skill, one replica) |
0.6 |
2 |
0 |
Minimum for Training (Pipeline) |
1 |
4 |
0 |
DU model Serving (ML Skill, one replica) |
1 |
4 |
0 |
DU model Training |
2 |
24 |
Strongly recommended |
The following table describes the required resources for small and average AI Center implementations. Note that these numbers are general guidance. In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
Use |
CPU |
RAM (GiB) |
GPU |
Disk (GiB) |
Small implementation:
4 |
32 |
0 |
Average implementation:
8 |
52 |
rancher partition = 80 GiB on the rancher partition
2 1 pipeline * 105GB = 105 Data disk
rancher partition = 160 GiB on the rancher partition
4 (2 pipeline + 1 DU pipeline) * 105GB = 315 Data disk
