- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
You might receive an error relating to the connection strings as follows:
Sqlcmd: Error: Microsoft Driver 17 for SQL Server :
Server—tcp : <connection string>
Login failed for user
This error appears even though all credentials are correct. The connection string validation failed.
Solution
Make sure the connection string has the following structure:
Server=<Sql server host name>;User Id=<user_name for sql server>;Password=<Password>;Initial Catalog=<database name>;Persist Security Info=False;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
Note:
User Id is case-sensitive.
