- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Configuring the Certificates
This page explains what certificate configuration entails at the time of installation.
The installation process generates self-signed certificates on your behalf. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
Aside from the above certificates, you may need to provide additional trusted CA certificates if you want the cluster to trust external services. Example: SQL Server CA Certificate, SMTP Server CA Certificate, etc.
Updating Cluster Certificates
The installation bundle provides a cluster management tool that enables you to update certificates post installation.
To access it, navigate to the location of the installer bundle:
cd /opt/UiPathAutomationSuite/
For instructions on updating the certificates, see Managing certificates.
Accessing a cluster that uses self-signed certificates
If you are using a self-signed certificate, take the following steps to access the cluster:
You need to add CA (Certificate Authority) Bundle certificate to the trust store for the following:
- Client machine
- Machine on which robot will run.
- Machine on which you will access Automation Suite from the browser.
- Server machine (requirement for air-gapped)
- Machine on which air-gapped bundle will be downloaded and extracted.
Use the following command to add the certificate to the trust store of the RHEL machine.
sudo cp --remove-destination rootCA.crt /etc/pki/ca-trust/source/anchors/
sudo update-ca-trust
