OUT OF SUPPORT
Last updated Feb 24, 2025
Setting a timeout interval for the management portals
Pre-installation, you cannot update the expiration time for the token used to authenticate to the host- and organization-level Management portals. Therefore user sessions do not time out.
To set a time interval for timeout for these portals, you can update the accessTokenLifetime property.
The following example sets the timeout interval to 86400 seconds (24 hours):
UPDATE [identity].[Clients] SET AccessTokenLifetime = 86400 WHERE ClientName = 'Portal.OpenId'UPDATE [identity].[Clients] SET AccessTokenLifetime = 86400 WHERE ClientName = 'Portal.OpenId'
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
