- Overview
- Requirements
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Troubleshooting
- How to enable Istio logging
- Redis Probe Failure
- RKE2 Server Fails to Start
- Exploring Logs
Network Requirements
We do not support firewalld. The Automation Suite installer automatically disables firewalld during installation; make sure it remains in a disabled state post-installation as well.
Automation Suite sets up default IP table rules on the host machines for necessary inter-node communication. We do not support custom IP table rules, such as those configured via firewalld, as they might conflict with IP table rules configured by Automation Suite. You can, however, apply extra firewall rules at the network level.
We recommend enabling firewall applications at the network gateway, but not between clusters.
This page lists the domains used by the various UiPath products (services), components, and integrations in an online deployment.
Add to your allow list those endpoints and ports for the UiPath products and services you use. For example, if you do not have AI Center, there is no need to add its required domains to your allow list.
To ensure cluster stability, your environment must meet the following requirements:
- Round Trip Time (RTT) between the nodes must be minimal (<10 ms RTT);
- High Availability requirements must be met.
- For downloading the required installer files and configuration scripts:
https://download.uipath.com
- downloads the installer script - For downloading container images and metadata:
https://registry-data.uipath.com
https://registry.uipath.com
The previous URLs are required during installation, for adding new nodes to an existing cluster, for upgrading to a newer version, and for application sync using ArogCD. These URLs may also be needed during runtime so that Kubernetes can pull the image.
- For using supportability tools, such as the support bundle generation and diagnostic tools:
https://sfbrprddeploywe.azurecr.io
https://sfbrprddeploywe.westeurope.data.azurecr.io
- For the installation of Kubernetes or RKE2:
https://rpm.rancher.io
- For sending business telemetry to UiPath®:
https://dc.services.visualstudio.com
This is only required if you opt in to send telemetry data to UiPath®.
Automation Suite portal
- For the Azure Active Directory integration:
https://login.microsoftonline.com/*
- (Optional) For application insights:
https://dc.services.visualstudio.com/*
Identity
https://graph.microsoft.com/*
- For the SQL connection: the connection you use, possibly through a pipeline
- For the Redis connection: the port number and password that are generated during Redis deployment
- For the Active Directory integration:
- Kerberos: port
88
- LDAP endpoints: port
389
- DNS for DC discovery:
port
53
- Kerberos: port
- For SAML authentication: SAML endpoints, as configured for Automation Suite
- For system email notifications: SMTP server and port, as configured for Automation Suite
- For certificate validation on connection, if CRLs need to be downloaded: the endpoint determined by the certificate
Webhooks
- HTTP(S) Webhook endpoints, as defined by users in the Orchestrator Webhook definition
Organization management
- For the Ceph integration: the connection is generated during infrastructure setup
Audit
Licensing
- For online license activation, update, and other online license operations:
https://activate.uipath.com/
- HTTP(S) calls via the Webhook connector
- HTTP(S) calls to Xray for Jira (on-premises or cloud), to ServiceNow, and to AzureDevOps
- The OOB models and metadata are fetched from our GitHub repository, and the models themselves are downloaded from our storage
account. The following URLs cannot be blocked as the OOB scheduler continues to run, and the last three URLs as they are needed
at runtime. Therefore, make sure that you have access to the following:
- The following are needed in order for the OOB metadata to fetch new models being added:
https://github.com
https://raw.githubusercontent.com
https://api.github.com
https://uipath.blob.core.windows.net
is needed to clone the new models downloaded- The following are needed at runtime for skill deployment and training pipeline for downloading dependencies:
- The Python Package Index:
http://pypi.python.org/
andhttp://pypi.org/
- Any Python PIP hosted public domains, based on your model package and required Python libraries in
requirements.txt
https://du-metering.uipath.com
Note:This URL is needed only when AI Center is connected to an external Orchestrator.
https://du.uipath.com
- For OCR:
- The UiPathDocumentOCR endpoint applicable for your region
- Microsoft OCR (optional): The endpoint applicable for your region
- Google OCR (optional):
https://vision.googleapis.com/v1/images:annotate
- For data extraction: the FormExtractor endpoint applicable for your region
- To download desktop clients:
https://download.uipath.com/TaskMining/sf/task-mining-setup.exe
(EXE) andhttps://download.uipath.com/TaskMining/sf/task-mining-setup.msi
(MSI) - For the SQL connection: the connection you use, possibly through a pipeline
- For the RabbitMQ connection: the connection is generated during infrastructure setup
smtp.sendgrid.net
(or whichever SMTP server is configured)- Any port-level blocks need to be accounted for.
- Any TLS or SSL certificates associated with the SMTP server should be verifiable without the need for a CRL fetch outside your offline environment.
https://dc.services.visualstudio.com/v2/track
If you use Azure infrastructure, you must allow the RHEL yum mirrors for Azure listed in this section.
These URLs are strictly applicable for Azure. If you use a different cloud services provider (CSP), the URLs are different.
http://rhui-1.microsoft.com
http://rhui-2.microsoft.com
http://rhui-3.microsoft.com
For your users to be able to access the official UiPath® documentation for Automation Suite and the bundled products, you must also allow documentation-specific URLs. For the full list, see UiPath® Documentation Website URLs.
/etc/sysctl.d/
folder, using the following command:
cat <<EOF >>"/etc/sysctl.d/99-sysctl.conf"
net.bridge.bridge-nf-call-iptables = 1
net.ipv4.ip_forward = 1
net.bridge.bridge-nf-call-ip6tables = 1
EOF
EOF
- The previous command is an OS level setting, and it is recommended to be used only by Linux admins. Ensure the changes you make are according to the control process of your environment.
- The
nf-call-iptables
is needed for most Kubernetes deployments. Kubernetes creates virtual networks internal to the cluster. This allows every pod to have its own IP address, which is used in conjunction with the internal name services to facilitate service-to-service communication. The cluster does not work withoutnf-call-iptables
enabled. For details, see the official Kubernetes documentation.
