Performing node operations
Documentation
How to scale your deployment by adding additional nodes.
How to safely remove a node from the cluster on a multi-node HA-ready production setup.
How to repave cluster nodes without any risks.
How to perform a graceful node shutdown.
Best practices for renaming nodes.
What to do before and after a node maintenance operation, to ensure the cluster is healthy.
Important:
RHEL kernel versions kernel-4.18.0-372.91.1.el8_6 and kernel-4.18.0-477.10.1.el8_8 are affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses these kernel versions either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libsdnf install -y kernel kernel-tools kernel-tools-libs
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
