Last updated Dec 23, 2025
AI Center considerations
On top of the core service requirements that are part of full platform requirements, AI Center requires additional resources, depending on the models that you want to run or train. For more details about the required GPU hardware generations and compatible NVIDIA drivers, refer to Compatibility Matrix.
Note: The following table describes the additional resources AI Center needs.
In this table, Data Disk is needed on all server nodes. This is not needed on agent nodes.
Use
CPU
RAM (GB)
GPU
Disk (GB)
Minimum for serving (ML Skill, one replica)
0.6
2
0
  • 20 GB on the rancher partition
Minimum for Training (Pipeline)
1
4
0
  • Minimum 51 GB AI Center disk partition(recommended 105 GB)
DU model Serving (ML Skill, one replica)
1
4
0
DU model Training
2
24
Strongly recommended
  • Minimum 51 GB Data Disk (recommended 105 GB)
Note: The following table describes the required resources for small and average AI Center implementations. Note that these numbers are general guidance.
Use
CPU
RAM (GB)
GPU
Disk (GB)
Small implementation:
  • 3 models served
  • 1 concurrent pipelines
4
32
0
  • 80 GB on the rancher partition1
  • 105 Data Disk 2
Average implementation:
  • 5 models served
  • 2 concurrent pipelines
  • DU model training
8
52
  • 160 GB on the rancher partition3
  • 315 Data Disk 4
1 (3 skills +1 pipeline) * 20 GB on the rancher partition = 80 GB on the rancher partition
2 1 pipeline * 105GB = 105 Data disk
3 (5 skills + 2 pipeline + 1 DU pipeline) * 20 GB on the rancher partition = 160 GB on the rancher partition
4 (2 pipeline + 1 DU pipeline) * 105GB = 315 Data disk
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
