Important!
Hardware and software prerequisites must be completed before proceeding with the installation.
Hardware and software requirementsFor a smooth installation experience, make sure to follow our best practices.
Installation best practices
Use the offline installation steps in this document when deploying UiPath Automation suite in a airgapped environment with no access to the internet.
The installation process has the following general steps:
Step | Description |
Step 1: Download the installation packages | This step needs to be performed from a machine with access to internet and to the air-gapped machines where Automation Suite will be deployed. While these are finishing downloading, you can continue to some of the next steps. This can be done from a Linux or windows machine. Step 1.1: Downloading the installation package Step 1.2: Getting all downloaded files on the first machine |
Step 2: Configure the installation | Run the interactive install wizard to configure the installation options The tool will gather inputs for most common install options and generate a configuration file that will be used during the installation. Configure advanced install options (Optional) The default install configuration includes the products used in core automation and a shared SQL server to be used by all products. To customize the products installed or have separate SQL servers used for specific products you can do so by editing the configuration file. Step 2.1: Basic configuration Step 2.2: (Optional) Advanced configuration |
Step 3: Copy the installation files on all the machines | On the first machine, copy the downloaded files in the installation folder created by the installation wizard at step 2. On the other cluster machines, copy the entire installation folder from the first machine to the same folder path on each machine. Step 3: Copy the installation files on all the machines |
Step 4: Run the installation | Create the cluster and join all machines From the first machine install the rest of the suite. Step 4: Running the installation |
Step 5: Complete the installation | Step 5: You have completed the installation successfully and can move to post-installation steps. You can now access the newly created cluster and suite, update certificates, resize the PVC, and more. Step 5: Completing the installation |
Step 1: Downloading the installation package and getting all the files on the first machine
You must perform this step on a machine with access to the internet and to the machines in the offline environment where Automation Suite will be installed.
Note:
This machine can be Linux or Windows. The commands in this guide are for RHEL-based OS. For Windows or other OSes, adjust for equivalent commands specific to those environments.
The Automation Suite installer is a wrapper of multiple packages that also installs some dependencies using Red Hat Package Manager (RPM). It provides an interactive experience that helps you configure external resources such as SQL and other installation options.
This section explains how to get the required files to start the installation process.
- Connect to a machine with internet access and run the following command to get the interactive wizard file:
ssh <user>@<dns_of_vm>
- If you used an SSH key, run the following command:
ssh -i <path/to/Key.pem> <user>@<dns_of_vm>
- Download the following packages:
installUiPathAS.sh
– Mandatory. See installUiPathAS.sh for download instructions.sf-installer.zip
– Mandatory. See sf-installer.zip for download instructions.sf.tar.gz
– Mandatory. See sf.tar.gz for download instructions.sf-infra.tar.gz
- Mandatory. See sf-infra.tar.gz for download instructions.du-ondemand.tar.gz
– Optional. Needed only for Document Understanding. See du-ondemand.tar.gz for download instructions.
Note: Not following this optional step limits the functionality of the Document Understanding services.du2110-ondemand.tar.gz
– Optional. Needed only for Document Understanding. See du2110-ondemand.tar.gz for download instructions.
Note: Not following this optional step limits the functionality of the Document Understanding services.cv-ondemand.tar.gz
– Optional. Needed only for Computer Vision. See du-ondemand.tar.gz for download instructions.
Note: Not following this optional step prevents access to the Computer Vision services.
Make sure to download the package suitable for your Automation Suite version and your operating system.
- Check that all files finished downloaded on the machine with internet access
- Create the target folder on the first machine
- Copy the files from the online machine to the first target machine
Create the installation folders by running the following command:
sudo su -
mkdir -p /opt/UiPathAutomationSuite/
chmod -R 777 /opt/UiPathAutomationSuite
mkdir -p /uipath/tmp
chmod -R 777 /uipath/tmp
Note: Running mkdir -p /opt/UiPathAutomationSuite/
is not required if you use the configureUiPathDisks.sh
script.
Copy the files to the first node by taking the following steps:
- From the machine with internet access, copy the files to the installation folder on the target machine, and the offline bundle(s) to the
/uipath/tmp
folder. - (Optional) To use Document Understanding, copy the following bundles to the
/uipath/tmp
folder. - (Optional) To use Computer Vision, copy the following bundle to the
/uipath/tmp
folder.
scp ~/installUiPathAS.sh ~/sf-installer.zip ~/sf-infra.tar.gz <username>@<node dns>:/uipath/tmp
scp ~/sf.tar.gz <username>@<node dns>:/uipath/tmp/
scp ~/du-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/
scp ~/du2110-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/
Note: Not following this optional step prevents access to the Document Understanding services.
scp ~/cv-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/
Step 2: Configuring the installation
- Add the prerequisites folder to the current PATH.
The interactive installer requiresjq
, which the Automation Suite offline bundles already include it. Run the following commands to add it to PATH, and make sure you are still root): - Provide permissions to the installer folder.
It is required to give adequate permissions to the/opt/UiPathAutomationSuite
folder where the install scripts are placed and will be executed.
The installer will also create some files (output.json
) after the execution of each stage.
To provide the necessary permissions, run the following command: - Run the interactive install wizard to configure the installation options.
The interactive wizard will guide through the configuration steps and generate the configuation that you can then customize and use through the remaining installation steps. - Run the script to start the interactive wizard:
chmod +x ./installUiPathAS.sh ./installUiPathAS.sh
mv /uipath/tmp/installUiPathAS.sh /uipath/tmp/sf-installer.zip /uipath/tmp/sf-infra.tar.gz /opt/UiPathAutomationSuite
cd /opt/UiPathAutomationSuite
unzip ./sf-installer.zip -d .
chmod +x ./bin/jq
export PATH=${PATH}:/opt/UiPathAutomationSuite/bin
chmod -R 755 /opt/UiPathAutomationSuite
Follow the steps in the wizard
Screen-by-screen sequence
- Enter the option for the multi-node HA-ready production mode.
- Enter option for air-gapped:
- Specify the URL for the cluster (DNS hostname/load balancer URL in multi-node HA-ready production mode) and the SQL Server information as shown below:
- Config will be generated with a folder as shown in the following image.
By running the installation using the default configuration, you are opting to run our basic product selection. You will install our core platform, Orchestrator, Insights, Action Center, Test Manager, Automation Ops, and Automation Hub.
You can configure the file for more advanced configurations. You can enable additional products, disable any of the default products, configure your SQL DBs and their respective connection strings, and certificates. For multi-node HA-ready production mode, we enable High Availability by default, but you can disable it if needed.
Step 3: Copying the installation files on all the other cluster machines
From the first machine in the cluster, where the configuration was performed, copy the entire install folder to all other machines.
- Copy the
folder to all other nodes by running the following command: - Add
-i <cert.pem>
if you are using a certificate to login. If you copy the.pem
contents to a local file, the new file will need to have correct permissions. You can dochmod 400 <cert.pem>
for granting them.
scp -r /opt/UiPathAutomationSuite <username>@<node dns>:/opt
Note: Since you are in an air-gapped environment, you might need to use the private IP of the target node.
Note:
The step above ensures the same configuration is replicated on all machines along with all the downloaded packages for the install bundle.
There are two types of machines: server and agent.
- Server - Machines on which the Kubernetes infrastructure (i.e. apiserver, etcd) runs on. These components manage the entire cluster.
- Agent - vanilla version of machine that is used to run workloads
The multi-node HA-ready production mode requires a minimum of 3 server machines. Installing Task Mining requires adding an additional machine used as an agent.
Note:
For a multi-node HA-ready production installation, you need a load balancer. Please make sure one was created and traffic is distributed between nodes. The domain name of the load balancer needs to be used in the
cluster_config.json
file.You need to have at least a server node and for HA you need at least three server nodes. An odd number of server nodes is required.
Step 4.1: Accepting the license agreement
Before running the installation, make sure to read the License Agreement.
To accept the license agreement, choose one of the following methods:
- Option 1 (Environment Variable) Set the
LICENSE_AGREEMENT
environment variable to accept
by executing the following command:
export LICENSE_AGREEMENT=accept
Alternatively, append --accept-license-agreement
to every execution of install-uipath.sh
Step 4.2: Creating and joining all machines to the cluster
- Set up the first machine.
Execute the following commands on the first server:
cd /opt/UiPathAutomationSuite ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /uipath/tmp --install-offline-prereqs --accept-license-agreement
- Join the rest of the servers to the cluster.
Execute the following commands on the rest of the server nodes in sequence:
cd /opt/UiPathAutomationSuite sudo chmod -R 755 /opt/UiPathAutomationSuite sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j server --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement
- Join the rest of the agents to the cluster.
Execute the following commands on the rest of the agent nodes in sequence:cd /opt/UiPathAutomationSuite sudo chmod -R 755 /opt/UiPathAutomationSuite sudo ./install-uipath.sh -i ./cluster_config.json -o ./output.json -k -j agent --offline-bundle ./sf-infra.tar.gz --offline-tmp-folder /opt/UiPathAutomationSuite/tmp --install-offline-prereqs --accept-license-agreement
Step 4.3: Finishing installing the suite
- Check if the nodes were properly added by running the following command:
sudo su export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin kubectl get nodes
- You should see more than one node in the list if all was well.
- Finish the installation by executing the following command:
Note: This is the most time consuming operation. Expect it to take ~2h.cd /opt/UiPathAutomationSuite ./install-uipath.sh -i ./cluster_config.json -o ./output.json -f -s --offline-bundle /uipath/tmp/sf.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
Loading the optional bundles commands
- To load the optional Document Understanding bundles, execute the following commands:
./install-uipath.sh -i ./cluster_config.json -o ./output.json --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp" --accept-license-agreement
./install-uipath.sh -i ./cluster_config.json -o ./output.json --optional-offline-bundle "/uipath/tmp/du2110-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp" --accept-license-agreement
./install-uipath.sh -i ./cluster_config.json -o ./output.json --optional-offline-bundle "/uipath/tmp/cv-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp" --accept-license-agreement
Note:
You have completed the installation successfully, and you can now move to post-installation steps.
Updating certificates
Important!
The installation process generates self-signed certificates on your behalf. However, the Azure deployment template also gives you the option to provide a CA-issued server certificate at installation time instead of using an auto-generated self-signed certificate.
Self-signed certificates will expire in 90 days, and you must replace them with certificates signed by a trusted CA as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
For instructions, see Managing certificates.
Accessing Automation Suite
To access the newly created cluster and suite, see Accessing Automation Suite.
Resizing PVC
To resize the PVC, see Resizing PVC.
If you installed AI Center, we recommend resizing the PVC to 200
immediately after the installation to avoid downtimes. For more information on this, check Resizing PVC for AI Center.
Updated 4 months ago
