- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
You must meet the hardware and software prerequisites before proceeding with the installation. See Hardware and software requirements.
You can use a dedicated script to validate the installation prerequisites and infrastructure readiness. See Validating the prerequisites.
For a smooth installation experience, make sure to follow our best practices. See .
The installation process has the following general steps:
Step |
Description |
Step 1: Download the installation packages |
You must perform this step from a Linux or Windows machine with access to the internet and to the offline machines where you plan to deploy Automation Suite. While the installation packages finish downloading, you can continue to some of the next steps. |
Step 2: Configure the installation |
Run the interactive installer to configure the installation options. The tool gathers inputs for most common installation options and generates a configuration file that you can use during installation. (Optional) Configure advanced installation options. The interactive installer offers a default experience with a limited number of configuration options. To customize the installed products, set up separate SQL servers for specific products, and more, edit the configuration file. |
Step 3: Copy the installation files on all the machines |
On the first machine, copy the downloaded files in the installation folder created by the interactive installer at step 2. On the other cluster machines, copy the entire installation folder from the first machine to the same folder path on each machine. |
Step 4: Run the installation |
Create the cluster and join all machinesInstall the rest of the suite from the first machine. |
Step 5: Complete the installation |
Step 5: You have completed the installation successfully and can move to post-installation steps. You can now access the newly created cluster and suite, update certificates, resize the PVC, and more. |
RHEL kernel version kernel-4.18.0-477.10.1.el8_8 is affected by an issue that interrupts the installation or management of the Automation Suite cluster. Make sure that none of the Automation Suite nodes uses this kernel version either pre- or post-installation. You can update the kernel version by running the following command:
dnf install -y kernel kernel-tools kernel-tools-libs
This machine can be Linux or Windows. The commands in this guide are for RHEL-based OS. For Windows or other OSes, adjust for equivalent commands specific to those environments.
The Automation Suite installer is a wrapper of multiple packages that also installs some dependencies using Red Hat Package Manager (RPM). It provides an interactive experience that helps you configure external resources such as SQL and other installation options.
ON THE SEPARATE MACHINE WITH INTERNET ACCESS
This section explains how to get the required files to start the installation process.
Make sure to take the following steps:
- Check that all files finished downloaded on the machine with internet access;
- Create the target folder on the machine;
- Copy the files from the online machine to the target machine.
ON ALL MACHINES IN THE CLUSTER
Create the installation folders by running the following command:
sudo su -
mkdir -p /opt/UiPathAutomationSuite/
chmod -R 777 /opt/UiPathAutomationSuite
mkdir -p /uipath/tmp
chmod -R 777 /uipath/tmp
sudo su -
is not required if you use the configureUiPathDisks.sh
script.
Copy the files to the first node by taking the following steps:
- From the machine with internet access, copy the files to the installation folder on the target machine, and the offline bundle(s)
to the
/uipath/tmp
folder:scp ~/installUiPathAS.sh ~/as-installer.zip ~/as-infra.tar.gz <username>@<node dns>:/uipath/tmp scp ~/as.tar.gz <username>@<node dns>:/uipath/tmp/
scp ~/installUiPathAS.sh ~/as-installer.zip ~/as-infra.tar.gz <username>@<node dns>:/uipath/tmp scp ~/as.tar.gz <username>@<node dns>:/uipath/tmp/ - (Optional) To use Document Understanding, copy the following bundle to the
/uipath/tmp
folder:scp ~/du-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/
scp ~/du-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/Warning: Not following this optional step prevents access to the Document Understanding services. - (Optional) To use Computer Vision, copy the following bundle to the
/uipath/tmp
folder:scp ~/cv-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/
scp ~/cv-ondemand.tar.gz <username>@<node dns>:/uipath/tmp/Warning: Not following this optional step prevents access to the Computer Vision services.
Running the interactive installer in multi-node offline mode
Run the interactive installer to configure the installation options. The tool gathers inputs for the most common installation options and generates a configuration file. High Availability is enabled by default, but you can disable it using the advanced configuration.
kubectl create token
default
, and only then execute the
command on the secondary nodes.
To install Automation Suite, take the following steps:
This step is optional.
You can configure the file for more advanced configurations. You can enable additional products, disable any of the default products, configure your SQL DBs and their respective connection strings, and certificates. For multi-node HA-ready production mode, we enable High Availability by default, but you can disable it if needed.
For advanced configuration, you can follow the following instructions: Advanced installation experience.
cluster_config.json
to all the other machines.
ON THE FIRST MACHINE IN THE CLUSTER
There are two types of machines: server and agent.
- Server - Machines on which the Kubernetes infrastructure (i.e. apiserver, etcd) runs on. These components manage the entire cluster.
- Agent - vanilla version of machine that is used to run workloads
The multi-node HA-ready production mode requires a minimum of 3 server machines. Installing Task Mining requires adding an additional machine used as an agent.
- For a multi-node HA-ready production installation, you need a load balancer. Please make sure one was created and traffic
is distributed between nodes. The domain name of the load balancer needs to be used in the
cluster_config.json
file. - You need to have at least a server node and for HA you need at least three server nodes. An odd number of server nodes is required.
Before running the installation, make sure to read the License Agreement.
To accept the license agreement, choose one of the following methods:
- Option 1 (Environment Variable) - Set the
LICENSE_AGREEMENT
environment variable to accept by executing the following command:export LICENSE_AGREEMENT=accept
- Option 2 (Inline parameter) - Alternatively,
append
--accept-license-agreement
to every execution ofinstall-uipath.sh
Finishing the installation on the first node
Once all nodes are joined, switch to the first server to finish the Automation Suite installation:
Check if the nodes were properly added by running the following command:
sudo su export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin kubectl get nodes
sudo su export KUBECONFIG=/etc/rancher/rke2/rke2.yaml PATH=$PATH:/var/lib/rancher/rke2/bin kubectl get nodes -
You should see more than one node in the list if all was well.
Finish the installation by executing the following command:
cd /opt/UiPathAutomationSuite ./install-uipath.sh -i ./cluster_config.json -o ./output.json -f -s --offline-bundle /uipath/tmp/as.tar.gz --offline-tmp-folder /uipath/tmp --accept-license-agreement
This is the most time consuming operation. Expect it to take approximately 2h.
Loading the optional bundles
This step is required only if you did not opt for external Docker registry.
To load the optional Document Understanding bundle, execute the following command:
./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"
./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/du-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp" -
To load the optional Computer Vision bundle, execute the following command:
./configureUiPathAS.sh registry upload --optional-offline-bundle "/uipath/tmp/cv-ondemand.tar.gz" --offline-tmp-folder "/uipath/tmp"
Completing an AI Center installation
If AI Center requires an external Orchestrator, run the following command to complete the installation:
./configureUiPathAS.sh aicenter configure --installation-token <identity token>
The installation process generates self-signed certificates on your behalf. These certificates are compliant with FIPS 140-2. The Azure deployment template also gives you the option to provide a CA-issued server certificate at installation time instead of using an auto-generated self-signed certificate.
Self-signed certificates will expire in 90 days, and you must replace them with certificates signed by a trusted CA as soon as installation completes. If you do not update the certificates, the installation will stop working after 90 days.
If you installed Automation Suite on a FIPS 140-2-enabled host and want to update the certificates, make sure they are compatible with FIPS 140-2.
For instructions, see Managing certificates.
To access the newly created cluster and suite, see Accessing Automation Suite.
- Overview
- Step 1: Downloading the installation packages and getting all the files on the first machine
- Step 1.1: Downloading the installation packages
- Step 1.2: Getting all downloaded files on the first machine
- Step 2: Configuring the installation
- Step 2.1: Default configuration
- Step 2.2: (Optional) Advanced configuration
- Step 3: Copying the installation files on all the other cluster machines
- Step 4: Running the installation
- Step 4.1: Accepting the license agreement
- Step 4.2: Creating and joining all machines to the cluster
- Step 4.3: Finishing installing the suite
- Step 5: Completing the installation
- Updating certificates
- Accessing Automation Suite
