Running High Availability with Process Mining
If you are running High Availability (HA) with Process Mining, you must change the Airflow scheduler helm chart from replicas:2 to replicas:1. Multiple replicas of the scheduler are not needed and cause instability when creating process apps and ingesting data with Process Mining.
To change the Airflow scheduler helm chart from replicas:2 to replicas:1, take the following steps:
  1. Gain access to the ArgoCD UI by following steps 1-5 in How to Troubleshoot Services During Installation.
  2. In the ArgoCD Experience, enter Airflow in the searchbar and open the card.
    docs image
  3. In the Airflow application, use the NAME filter to select the airflow-scheduler and the KINDS filter to select the Deployment to see the deploy step of airflow-scheduler.
    docs image
  4. Select on the airflow-scheduler deploy card to open its details. You should see its summary of KIND set to Deployment and NAME as airflow-scheduler.
    docs image
  5. In the LIVE MANIFEST section, select Edit and locate the section of the manifest under spec: where replicas:2 and the selector match labels for airflow-scheduler.
    docs image
  6. Change the replicas to replicas:1 and select Save.
    docs image
Warning:
Selecting the SYNC button in the Airflow application will reset the value back to replicas:2.
docs image
The value might also be reset if you enable SELF-HEAL in the airflow APP DETAILS screen.
docs image
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
