- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. Refer to the following table for the names you need to use.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
The following table lists out the database names and their corresponding format.
Product / service |
Default database name |
Connection string format |
Shared Platform Capabilities |
Orchestrator |
Action Center |
Automation Suite Robots |
Automation Hub |
Data Service |
Insights |
Test Manager |
Task Mining |
AI Center |
Apps | AutomationSuite_Apps1 | |
Document Understanding |
Process Mining |
AutomationSuite_ProcessMining_Warehouse2AutomationSuite_Airflow3 |
AutomationSuite_ProcessMining_Warehouse uses both ADO.NET and PYODBC formats.
AutomationSuite_Airflow uses PYODBC connection string format. AutomationSuite_Airflow must have READ_COMMITTED_SNAPSHOT enabled when creating databases manually. The connection to the AutomationSuite_Airflow database can not begin with a { character.
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
- for SQL: add
'at the beginning and end of the password, and double any other'. - for JDBC/ODBC: add
{at the beginning of the password and}at the end, and double any other}.
You could use the databases in an elastic pool for better cost-effectiveness.
SQL collation
SQL_Latin1_General_CP1_CI_AS at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
dbcreator role to the SQL account used to connect to the database.
db_owner and db_securityadmin roles for all Automation Suite databases.
db_owner, then the SQL account should have the following roles and permissions on all databases (the only exception is Insights which
still requires db_owner).
db_securityadmindb_ddladmindb_datawriterdb_datareaderEXECUTEpermission on dbo schema
db_securityadmin and db_ddladmin roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards.
Only the listed SQL ciphers are supported in Automation Suite:
TLS_AES_256_GCM_SHA384TLS_CHACHA20_POLY1305_SHA256TLS_AES_128_GCM_SHA256TLS_AES_128_CCM_SHA256ECDHE-ECDSA-AES256-GCM-SHA384ECDHE-RSA-AES256-GCM-SHA384ECDHE-ECDSA-CHACHA20-POLY1305ECDHE-RSA-CHACHA20-POLY1305ECDHE-ECDSA-AES256-CCMECDHE-ECDSA-AES128-GCM-SHA256ECDHE-RSA-AES128-GCM-SHA256ECDHE-ECDSA-AES128-CCMECDHE-ECDSA-AES128-SHA256ECDHE-RSA-AES128-SHA256ECDHE-ECDSA-AES256-SHAECDHE-RSA-AES256-SHAECDHE-ECDSA-AES128-SHAECDHE-RSA-AES128-SHAAES256-GCM-SHA384AES256-CCMAES128-GCM-SHA256AES128-CCMAES256-SHA256AES128-SHA256AES256-SHAAES128-SHADHE-RSA-AES256-GCM-SHA384DHE-RSA-CHACHA20-POLY1305DHE-RSA-AES256-CCMDHE-RSA-AES128-GCM-SHA256DHE-RSA-AES128-CCMDHE-RSA-AES256-SHA256DHE-RSA-AES128-SHA256DHE-RSA-AES256-SHADHE-RSA-AES128-SHAPSK-AES256-GCM-SHA384PSK-CHACHA20-POLY1305PSK-AES256-CCMPSK-AES128-GCM-SHA256PSK-AES128-CCMPSK-AES256-CBC-SHAPSK-AES128-CBC-SHA256PSK-AES128-CBC-SHADHE-PSK-AES256-GCM-SHA384DHE-PSK-CHACHA20-POLY1305DHE-PSK-AES256-CCMDHE-PSK-AES128-GCM-SHA256DHE-PSK-AES128-CCMDHE-PSK-AES256-CBC-SHADHE-PSK-AES128-CBC-SHA256DHE-PSK-AES128-CBC-SHAECDHE-PSK-CHACHA20-POLY1305ECDHE-PSK-AES256-CBC-SHAECDHE-PSK-AES128-CBC-SHA256ECDHE-PSK-AES128-CBC-SHARSA-PSK-AES256-GCM-SHA384RSA-PSK-CHACHA20-POLY1305RSA-PSK-AES128-GCM-SHA256RSA-PSK-AES256-CBC-SHARSA-PSK-AES128-CBC-SHA256RSA-PSK-AES128-CBC-SHA
Automation Hub and Document Understanding require the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Automation Hub tenants and Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also check here all the components that can be added to the SQL Server, which includes also Full-Text Search.
.json functions.
For Azure SQL, ensure the database is S3 service objecservice objective or above.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
Data Service requires SQL Server version 2016 or higher.
Latin1_General_CI_AS.
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};1433 for Airflow database connections.
Non-standard SQL server ports are not supported.
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database is installed, is set to UTC.
AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps.
AutomationSuite_ProcessMining_Warehouse.
To calculate the hardware requirements, you need to have an indication of:
- the number of (million) events in your process.
the number of case and event fields in your output data. For example, in TemplateOne this would be 30.
Note: In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the Capacity calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed.
See also Hardware requirements.
db_securityadmin database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL Server. For details,
see the official Microsoft documentation on Database-level roles.
See also Configuring process app security.
Requirements for AI Center connected to an external Orchestrator
AutomationSuite_Platform for
AI Events and AI Storage services.
Requirements for AI Center installed on a FIPS 140-2-enabled machine
Before starting the Automation Suite installation, take the following steps:
Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
nmap -sV -p <port> -vv --script ssl-cert domainnmap -sV -p <port> -vv --script ssl-cert domain
During the Automation Suite installation, take the following steps:
Append the following values to the AI Center
sql_connection_string_template_jdbcconnection string in thecluster_config.jsonfile:encrypt=true;trustServerCertificate=false;fips=true;.Example:
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"For details on database configuration, see Advanced installation experience and Updating the SQL database.
Add the exported cert from step 1.c. to the trust store of the host machine. For details see Updating the CA Certificates.
READ_COMMITTED_SNAPSHOT option is set to ON.
READ_COMMITTED_SNAPSHOT is enabled or disabled:
SELECT is_read_committed_snapshot_on FROM sys.databases
WHERE name like 'PLACEHOLDER' SELECT is_read_committed_snapshot_on FROM sys.databases
WHERE name like 'PLACEHOLDER' Make sure to replace PLACEHOLDER with your Orchestrator database name.
1.
0. Use this query to enable it:
ALTER DATABASE PLACEHOLDER
SET READ_COMMITTED_SNAPSHOT ONALTER DATABASE PLACEHOLDER
SET READ_COMMITTED_SNAPSHOT ONREAD_COMMITTED_SNAPSHOT must be enabled on those as well.
- Databases
- SQL collation
- Permissions
- SQL server ciphers
- SQL requirements for Full-Text Search
- SQL requirements for Insights
- SQL requirements for Data Service
- SQL requirements for Process Mining
- SQL requirements for AI Center
- Requirements for AI Center connected to an external Orchestrator
- Requirements for AI Center installed on a FIPS 140-2-enabled machine
- SQL requirements for Orchestrator
