Failed status when creating a data labeling session
Description​
If you are not able to create data labeling sessions on Data Manager in AI Center, take the following steps.
Solution​
Please double-check if Document Understanding is properly enabled. You should have updated the configuration file before the installation and set documentunderstanding.enabled to True, or you could update it in ArgoCD post-installation as described in Solution 2.
After doing that, you need to disable it and disable AI Center on the tenant you wish to use the Data Labeling feature on, or create a new tenant.
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
