Last updated Dec 23, 2025
Exploring summarized telemetry
Viewing summarized telemetry XML file
To view the XML file generated with the support bundle that summarizes basic usage telemetry you can open the XML file using SQL Sever Management Studio or in any XML viewer you are familiar.
  • Viewing summarized telemetry XML file
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
