- Overview
- Requirements
- Q&A: Deployment templates
- Configuring the machines
- Configuring the external objectstore
- Configuring an external Docker registry
- Configuring the load balancer
- Configuring the DNS
- Configuring Microsoft SQL Server
- Configuring the certificates
- Online multi-node HA-ready production installation
- Offline multi-node HA-ready production installation
- Disaster recovery - Installing the secondary cluster
- Enabling Redis High Availability Add-On for the cluster
- Document Understanding configuration file
- Cluster administration
- Monitoring and alerting
- Migration and upgrade
- Migration options
- Step 1: Removing old Identity cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Clearing Redis data
- Step 4: Validating the Insights migration
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- GPU node affected by resource unavailability
- Failure to resize PVC
- Failure to resize objectstore PVC
- Storage reclamation patch
- ArgoCD login failed
- Redis probe failure
- RKE2 server fails to start
- Issues accessing the ArgoCD read-only account
- Pods stuck in Init:0/X
- Failure to configure email alerts post upgrade
- No healthy upstream issue
- Document Understanding not on the left rail of Automation Suite
- Failed status when creating a data labeling session
- Failed status when trying to deploy an ML skill
- Migration job fails in ArgoCD
- Handwriting recognition with intelligent form extractor not working
- Failed ML skill deployment due to token expiry
- Exploring Logs
Last updated Sep 5, 2025
To configure AD integration, refer to Configuring SSO: Active Directory.
If AD integration and authentication were enabled in the standalone deployment, take the following steps in the Automation Suite cluster:
- Make sure the domain controllers are discoverable by the Automation Suite cluster. If not, use the Kube DNS configuration;
- Configure integrated Windows authentication and Kerberos authentication using keytab file;
- Configure LDAP integration via the Portal under the host admin;
- Configure Windows authentication via the Portal under the host admin;
Configure LDAPS for secure connection to LDAP.
Note: The account used for the LDAP integration configuration should only have read access to all trusted domains in the current and trusted forests.
