Failure to resize PVC
Description​
In certain situations, the PVC resize operation using ./configureUiPathAS.sh can fail. This issue is caused by the underlying longhorn resizing operation.
Solution​
To unblock the PVC resize, it is necessary to manually intervene and scale up the deployment.
If error messages are displayed while resizing the PVC, you need to retry the PVC resize operation. If you notice that the number of retries is exceeding 30, you need to manually scale up the deployment using the command:
kubectl scale deploy -n <namespace> <deployment-name> --replicas=1
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
