Airflow installation fails with sqlalchemy.exc.ArgumentError: Could not parse rfc1738 URL from string ''
Possible cause​
The sqlalchemy PYODBC connection strings for Process Mining are not defined correctly in the cluster_config.json.
Solution​
  1. Check the processmining section in the cluster_config.json to verify if connections strings are specified properly.
  2. Check if there is sqlalchemy_pyodbc_sql_connection_str specified.
Note:
If the sqlalchemy_pyodbc_sql_connection_str is not specified in the processmining section it should be specified in template string sql_connection_string_template_sqlalchemy_pyodbc
  • Possible cause​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
