Last updated Dec 23, 2025
Issues accessing the ArgoCD read-only account
During installation, the proper RBAC configuration is not applied, which results in issues accessing the ArgoCD read-only account.
Solution
If you encounter this problem, use the following workaround:
kubectl -n argocd patch cm argocd-rbac-cm -p '{"data": { "policy.csv": "p, role:uipath-sync, applications, get, */*, allow\np, role:uipath-sync, applications, sync, */*, allow\ng, argocdro, role:uipath-sync\n"}}'kubectl -n argocd patch cm argocd-rbac-cm -p '{"data": { "policy.csv": "p, role:uipath-sync, applications, get, */*, allow\np, role:uipath-sync, applications, sync, */*, allow\ng, argocdro, role:uipath-sync\n"}}'
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
