Failure to configure email alerts post upgrade
Description​
After upgrading from Automation Suite 2022.10, the continue field in Alertmanager's uipath-event-listener receiver configuration incorrectly remains set to false. This issue affects the configuration of email alerts and multiple receivers.
Solution​
To fix the issue, you must manually set continue to true in the alertmanager-config-tmp secret:
  1. Retrieve the existing Alertmanager configuration in a file named am_config.yaml:
    kubectl get secret alertmanager-config -n cattle-monitoring-system -o jsonpath="{.data.alertmanager\.yaml}" | base64 --decode > am_config.yaml
  2. Edit the am_config.yaml file and set the continue field value to true, as shown in the following example:
  3. Encode the configuration to Base64 format:
    openssl base64 -A -in am_config.yaml > am_config_base64.yaml
  4. Patch the alertmanager-config secret with the updated Base64 data:
    kubectl patch secret alertmanager-config -n cattle-monitoring-system -p $'{"data":{"alertmanager.yaml":"'$(<am_config_base64.yaml)'"}}'
  • Description​
  • Solution​
Connect
Stay updated
